Sounds like the oven ignitor is weak. If everything else is working it must be a bad ignitor. These are usually easy to replace and can expect to pay $70-$100 for the part. Check to see if it glows when in bake mode first. If it does then replace the ignitor. You can look at the ignitor, when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced
http://www.theignitorstore.com/catalog/s...
http://www.reliableparts.com/catalog/Gaf...
you may find your part her.
if this solves your problem please accept the solution
Ignition problems are always caused by electrical issues. The igniter is always powered by the the electrical current which flows into the unit. Most units after cleaning either by self clean cycles or manual cleaning most often come up with ignition problems. All you need is an expert to help you take a look at the unit and most likely clean the ignition lines this will stop the malfunction. Although if the continuous sound of the ignition worries you after the unit comes on you can simply unplug the unit from its power source and the continuous clicking will stop. You can use this method pending when you get an expert to fix the unit.
Do you know where I need to look on the oven to find the ignitor?
I'm not sure where on the oven itself I should be looking to see the ignitor.
