Question about Oster OGB61101 Microwave Oven
No heating, still cold - Oster OGB61101 Microwave Oven
    New Friend:
    Problem Solver:
  • 7 Answers
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Posted on Sep 14, 2011
  • Oster Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
Posted on Jun 28, 2011
SOURCE:
Microwave heats up and cooking, but taking ages to complete. For instants, a cup of cold coffee takes 2,5 min. To boiling point.
why do you want it boiling ? I like mine drinkable and that takes at most 40 seconds when cold
Jan 12, 2018 | Microwave Ovens
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    Hi at the back of my fridge freezer i think the compressor at the bottom is very hot, also the small pipes at the back is not heating as much as the compressor, actually anything but hot but not cold...
    It possibly needs re gassing. Call a refridgeration expert in to look at it for you, there is nothing you can do without the gas bottles and evacuator.
    Hope that helps.
    Jan 04, 2011 | Microwave Ovens
    Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    heatman101
    Sep 14, 2010 | Emerson Microwave Ovens
    Microwave not heating any food
    Basic Microwave Oven TroubleshootingTips
    heatman101-0=-0
    May 10, 2010 | Maytag MMV4205 Microwave Oven
    Not heating up anything
    Tat would be a magnetron problem. The magnetron is what provides the heat
    Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Miocrowave is not heating, item stays cold
    hello. I can help you.
    When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
    Jun 15, 2009 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
    No heat
    heating element stopped working
    easiest thing is to get a new microwave
    Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
    This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
    Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
    Oster OGB61101 Microwave Oven Logo
    959 people viewed this question
    Top Oster Microwave Ovens Experts
    William Miller
    William Miller
    Lawrence Oravetz
    NOEL
    NOEL
    Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
