Question about Olympus EVOLT E-500 Digital Camera
A red line appears in center of my pictures .
I have recently started to see a fine red line in the center of my downloaded pictures and also when I view the pictures on my camera. It does not matter what lens I use, this is happening with all lenses.
I am not sure if I have accidently pressed a setting that I am unaware of or if this could be a problem that needs repair.
Does anyone have an idea of what this could be?
  • dgreilich Dec 20, 2008
    I have noticed a similar problem recently, when taking photos in low light a very faint red line appears on the right side of the screen. It does not appear at all in bright light (natural sunlight only). I have been photoshopping it out but I would like to get it fixed.
    Master:
  • 383 Answers
There is a light leak in the CCd .... Service centre is the Solution
Posted on Oct 12, 2008
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
Jan 22, 2010 | Samsung LN46B640 LCD TV
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
Lines in the picture but no red lights
is it under warranty? if it is get a new one. if not you can open it andclean it out as good as you can. its getting hot on the video chip and thats why.
Apr 17, 2009 | Microsoft Xbox 360 Console
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Horizontal lines have recently started appearing in all photos
I just took mine to casio and they repaired it for free even though warranty was up. I would contact them.
Nov 06, 2007 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Red lines on screen when recording
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Nov 19, 2006 | Panasonic NV-GS200 Mini DV Digital...
Olympus EVOLT E-500 Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
