Question about Dell Latitude C640 Notebook
Water spill on laptop
Water spill on Dell 640c and since then the keyboard malfunctions. CD drive no longer reads CD's
  • mykefty Aug 23, 2008
    have ripped it open, dried the parts and coupled it back. some keys on the keyboard are not working. do u think its the keyboard or its driver?
    i would dry the keyboad right away.
  • Dell Master
  • 13,433 Answers
You need to take it to a professional for repair.
if you know how to take a laptop apart, you could do it yourself.
Dry the parts, might need to replace the broken parts.
Posted on Aug 23, 2008
  • Ekse Aug 23, 2008
    Its a hardware issue for sure, have you taken the keyboard apart and dryed it?
  • Ekse Aug 23, 2008
    you might have to replace the keyboard if it doesn't work after a full drying and taking it apart.
Laptop does not recognize cd drive
Hi there. Sometimes CD drives malfunction. If it will no longer read a CD, chances are that you will need to get a new CD drive. Make sure to try multiple CDs before you replace it, just to make sure that a single CD isn't the point of failure. Good luck. -Alex
Aug 12, 2011 | Dell Computers & Internet
Juice spilled on dell laptop,the problem is when i press certain keys 3 or 4 letters apear,it is the same with a new keyboard
If that happens with a new keyboard then the mother board is faulty and a replacement laptop is on the horizon. What happens with an external (USB) keyboard?
Hope this helps.
Feb 03, 2011 | Dell Inspiron 1525 Laptop
Spilled water on the keyboard. want to remove keyboard.
here's the link to your laptop's Service Manual. If you're patient and start from the beginning, the keyboard will be relatively easy for you to remove.
http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Aug 10, 2010 | Dell Inspiron 2200 Notebook
Water was spilled on the keyboard. Dryed out laptop but keyboard shorted out. Everything works fine but some keyboard characters don't type out. Can keyboard be replaced on this laptop?
You definitely need to replace the keyboard on the system.If your system still within warranty and you have Complete Care warranty from Dell this will be covered, if not you may need to pay for it or purchase a keyboard part.
Jul 29, 2010 | Dell Inspiron 1545 Notebook
Water damage
The only solution is send it back to service center. Maybe to many part malfunction
Not worth it to repair it,.
May 13, 2010 | Dell Latitude D600 Notebook
The keys have clogged up and all the keys dont work becouse water has gone iside any solutions
Replacement.
That is the ONLY solution for keyboards that have ANY kind of liquid spilled into them.
I can replace the keyboard and check the inside of the computer for additional damage that may have occurred because of the spill.
Jan 24, 2010 | Dell 0Y3740 Keyboard
Water spilled into my laptop Dell Latitude D600. what do i do
  1. Disconnect any power and remove the battery
  2. Tilt the system in various angles to drain as much of the water from the system as possible.
  3. Let the system dry for several days, (I'd say a minimum of 4) is a relatively warm place
  4. Insert Battery, see if system will power on.
If the system was powered on when the spill occurred and turned off by itself during the spill, then the motherboard has most likely been damaged and will need replacement. ($100 or so on EBay)
If the system will not power on after drying, you might consider replacement rather than repair as the cost of fixing it could exceed the replacement cost. (Dell has portables starting around $399)
http://www.dell.com/us/en/home/notebooks/laptop-inspiron-1545/pd.aspx?refid=laptop-inspiron-1545&s=dhs&cs=19
Dec 24, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Dell notebook keyboard malfunction
try to press the key using screw driver or any pin that you can press into the keyboard..but remove first the top key..try pressing with some screw if its typing,if not its mean the logic board is damage and you need toreplace a new one...if working with the screw pressing..repalace with a key button only with the same lock.
Jan 04, 2009 | Computers & Internet
I suspect just as you suggested something was spilled on it. Other than loose keys laptop keyboards are generally not repairable. They are not that difficult to replace, but check the Service Manual before deciding to do it yourself.
Dec 17, 2008 | Dell Inspiron 1525 Notebook
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude C640 Notebook Logo
176 people viewed this question
Alun Cox
