Question about KitchenAid Kitchen Ranges
How do I remove the control panel on a Kitchenaid KERC607 stove
How do I remove the glass panel where the contols are located . Some moisture has got in there and I need to dry it.
Posted on Nov 11, 2008
SOURCE:
Kitchenaid Superba KERC607 oven light bulb is out.
Try tightening it first clockwise just a little then undo it,sometimes you have to get a bit physical with these things! make sure the main switch/isolator is off,take out lamp,note type and replace.
Jan 10, 2014 | KitchenAid KERC607 Electric Kitchen Range
How to remove control panel
Service manual
Note: remove the back splsh panel to access the control. UNPLUG the stove. It is always hot from L-2 to oven elements. Unplug this puppy before attempting repairs. MORE SERVICE MANUALS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2012 | KitchenAid KERA807P Electric Kitchen Range
I have no power to my range. I accidently touched the side and center of the oven light bulb socket while trying to get the broken off light bulb base out ot the socket without unpluging. The inline fuse...
I have exactly same issue. No power to my KitchenAid (Whirlpool) YKESC307BW6. I tried to bend the oven light socket with a screwdriver (with power on) like a dufus. I already had an issue with control panel relays for ovn elements fried. I plan to get a new control panel but need to be sure its the conrol panel. Did you find the issue and was it control panel replacement? Thanks
Nov 03, 2010 | KitchenAid KERC607 Electric Kitchen Range
Our KitchenAid Model KERC607 always has the symbol for temperature probe on the display, thinking the probe is plugged in, and pressing "Cancel" does nothing to remove the symbol. We don't even own a...
this obviously not an isolated problem.
Go here and see what they have to say...
http://www.applianceblog.com/mainforums/kitchenaid/12867-kitchenaide-issues-temp-probe.html
Here is good information about appliances. Why re-invent the wheel
Sep 28, 2010 | KitchenAid KERC607 Electric Kitchen Range
Is my oven self-cleaning?
Here is the link you need to download the manual for your stove, you will need the serial number from the stove to select the right manual for you.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KERC607&siteCd=KAD
please do not forget to rate and comment about your experience with fixya today.
Dec 27, 2009 | KitchenAid KERC607 Electric Kitchen Range
I need the part number for the left rear burner switch on model Kitchenaid KERC607HWW8
The part number for the infinite switch that controls the left rear burner on this model range is 9751364. This is a 1500W rated switch that lists for about $33 at appliancepartspros.com. I hope this helps you.
Nov 23, 2009 | KitchenAid KERC607 Electric Kitchen Range
Kitchen aid electric stove does not go on
check the door lock switches on the door lock they get bent out of sdhape real easy
Jun 29, 2009 | KitchenAid KERC607 Electric Kitchen Range
Kitchen Ranges Logo
229 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
