Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Sound too loud using the remote control Model #40312S&CC Unit. How do you disconnect remote control from Juke box?
    Champion:
  • Wurlitzer Expert
  • 211 Answers
If it is an infrared remote control like a TV remote, then you just take the batteries out.
Posted on Oct 20, 2008
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
Rockola Model 490 2 Super Sound Juke Box wont power on
(1) Make sure the wall outlet has power. (2)Make sure the power switch is "on" (3) check the fuses. If you discover a blown fuse, be sure to replace the fuse with the correct value. If it blows again, you may have a more serious problem.
May 26, 2013 | Audio Players & Recorders
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
Mitsubishi TV Model CS-27201 has picture for about 20 seconds after turning on, then a black mask covers all but the edges of the screen - sound is still on. It just happened for reasons unknown. But has...
Your TV is set to one of the CC [closed captioning] modes, particularly Text 1-Text 4. Make sure you use your remote control to set cc to off. This black box will go away.
Jun 29, 2008 | Televison & Video
Remote use ofr power off/on
The On/Off switch on a One More Time CD remote unit doesn't actually turn the jukebox on and off. Strange but true! You're not missing anything, honestly. I think the button was/is related to switching on an external background music through the jukebox but only if you have the correct adaptor in the box already.
The problem can be overcome by buying a remote controlled mains adaptor plug. You plug the juke into the adaptor and the adaptor into the wall. You can then turn it on and off using a small remote button supplied with it.
Dave.
Apr 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Jukebox
Plug your MOSMP036 into your USB port on your computer. Find it in "Device Manager". Double click on it then go to "Driver". Click on "Update Driver", then on "Next" then "Next" again and again to search for suitable driver. DO NOT INSTALL the driver it says is nearest match but click on the "Install one of the other drivers box and click "Next". Select the driver for USB mass storage device and click next. You will now be able to find your MP3 player's disc in Widows Explorer where you can create folders and copy and move files at will. Just remember when you have finished to go into MOS Jukebox, click on Sync the on File and then on Exit, otherwise your player menu will not display your songs as you have installed them. Iuse my MOSMP036 to back up my important computer files!
Aug 09, 2007 | Ministry Of Sound MOSMP036 MP3 Player
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
79 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
