Question about Canon PIXMA MP600 all-In-One InkJet Printer
Incorrect color of photos
When I go to my picture gallery and select a photos to print (on my mp600 printer) the color of the photo is off, the flesh tone is a redish color. when printing off of my card in the printer the color is perfect. However, I have lots of photos saved on my HP. What do you suggest?
  • Anonymous Sep 16, 2008
    When glossy paper or high quality are select pictures come out a orangey colour
I found out that Windows Vista (this is what came with my HP laptop) is not compatible with my printer. So, I went to the Canon website and downloaded a driver, and my photos are very clear and of normal color:)
Thanks for checking and your response time was pretty quick.
Karen
Posted on Aug 24, 2008
SOURCE:
HOW CAN I PPRINT PHOTOS THAT ARE TRURER TO THE DIGITAL PICTURE ON THE MONITER? IS THERE ADJUSTMENTS THAT I CAN MAKE?
If you're using a good photo software there are many adjustments. I use Canon printing software, and Photo Gallery that you can get with Windows Vista. Most all have a place to adjust contrast brightness, color, hue, and even cropping and enlarging. In control panel, printer properties, printing preferences you can adjust all of these in there.
Feb 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Print photos from c drive and not from memory card
Simply right click on the image file you wish to print from your C: drive and choose Print. A menu will come up and you should make sure your MP600 is the selected printer. From the menu, you'll also be able to choose resolution, size,and other options. When you have all settings the way you like, hit Print and you're done.
Sep 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I cannot scan photographs to computer
hi! there,
well,if you are trying to print a photo under photo album
and you want to select photo or you are to fetch photo, if you click this you are going to menu of your windows exactly, on that you go to my picture,on that menu select your picture to print,if you selected your picture your going back to your photo print menu in this photo print menu it will flash your picture to print,there option there before you print,set all this e.i your photo size 4x6,5x10 or wallet size depend on you,on lay out you have to select how does it print on you photo paper is it 4 pic on one photo paper or 6 etc..the thing is it has you to return in menu in order to flash your photo,this will help you print your own photo no need to go to your photo shop to develop it easy.cheers have a good day thank's to log in fixya don't forget to rate me.
Apr 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Aug 15, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Printing digital photo on 8x11
Right click on the photo to be printed and select edit. When the picture is displayed pull down file and select 'page set up'. Set to fit 1 to 1 pages. Leave the margins and center were they're at. Pull down file and select 'print preview'. If this fits covers most of the page , type c (this closes this window and returns you to the previous one).and pull down file and select 'print'. If not again type c, select file and 'page set up' again and select land scape. If this is better, print this
May 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Pink tinge to colored photos
Canon has a number of things you can check in their knowledgebase. Go here. Type "pink tint" in the search box and click Search. If you select the first item "tinted printing" you will get at least 21 things you can try (only 10 show up per screen).
Apr 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Having problems printing photos from photo gallery.Printer prints pictures from previous attemts and not the one required.I have uninstalled thed programme but disconnected the printer first.Was this wrong...
Open the photo from photo gallery, doubleclicking orn it or selecting it with one click. Ensure in last case it is marked in blue. It should print the right photo in this way.
Apr 10, 2008 | Office Equipment & Supplies
Error B8e7b69c
I have had this issue happen to me when trying to print a photo from my windows picture program and from the window photo gallery program on Vista. I believe the problem is a compatibility issue with the windows Vista photo programs. I was able to print very well using another photo program. So i suggest printing from another photo program. My camera came with one that is pretty basic and good at fine tuning the pictures. I used the Canon zoombrower ex program and it printed all my pictures well. I think most digital cameras come with some type of photo editing program. You should try printing from it instead widows photo folders or windows photo gallery. Using my camera's photo software solved my issue well. try this out to see if it works for you. good luck
Mar 20, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
122 people viewed this question
Clive
Clive
old marine
old marine
Ekse
