Question about Zanussi ZHQ575 Electric Double Oven
How to fit my oven Zanussi ZUF270X (944171377) when i have cabinet 60cm( outside) 56,5cm inside and my oven is 59,5cm. It doesn't have space for fitting that means it's retangular and no T-shape for build-in. If You can halp my i will be very happy. Thank You, Joanna. This is my e-mail (jadamek05@aol.com)
As its a built under oven not built in you need to remove the oven housing cupboard and screw the bracket to the two cupboard sides.
Posted on Nov 22, 2008
    President:
  • 1,462 Answers
You will have to modify your cabinet
Posted on Aug 23, 2008
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
I have a GE wall oven, model # JKP07G004B0 and I would like to replace it. I need to know which new one will fit the space.
Since it is so old the diminsions are no longer available online and the only way to get the size is pull it out 4-6 inches and measure height,width and depth of the cut out portion of the cabinet it fits into
GENE
Jul 30, 2011 | GE Ovens
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
I have zanussi ZBS863 oven/grill but the grill not heating up as much as it used to and not cooking stuff properly, the outside part of grill still red but inside bar looks like it isn't working
It's a dual grill which uses the outside bar on full grill and /or oven. The innder is used on grill only. This part is open circuit and needs to be replaced.
Dec 07, 2009 | Ovens
Zanussi zuf270x main oven not getting hot
I've just mended this myself and it took about 15 mins:-)
It's more than likely the heating element, you can get one off the internet for about £20 if you go for the electrolux replacement.
Open oven door and remove the trays, undo the four small screws on the back wall inside - not sure if you have to, but I turned the power off at this point. Better safe than not! Turn this around to the right wall as it won't come right out due to the bit of wire on the right (temp sensor maybe?).
If you've already got the new element you can guess what happens next; take out the 3 small screws holding in the element and gently pull towards you. It's attached to two wires poking out of two holes - take the bottom one off first as it seemed to have less tendency to fall back in the hole (I reckon that could be a real pain to get back).
Hold the wire still and wiggle the old element to remove as you will have less chance of damaging the wire that way. Reconnect the wires to the new element and pop it back together again.
Job done and after a year of waiting we now have double the oven space!
Jul 29, 2009 | Zanussi ZHQ575 Electric Double Oven
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
Mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Apr 10, 2008 | Ovens
Zanussi ZHQ575 Electric Double Oven Logo
347 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
