SOURCE: amp settings
It's going to be mainly "what sounds best", but I'll give you a start.
The other settings are going to be based on how the system is connected to the head unit.
SOURCE: humming noise in amp
You must break it down through a process of eliminating items. With the system running unplug the RCAs from the amp. Do you still hear the noise? Try turning the gain down on the amp a bit and increasing the subwoofer level on the head unit instead. Make sure you have a low pass crossover set (probably below 80Hz).
Does the noise change with engine RPM?
Try a different RCA cable. I find that most times noise filters will make the problem worse not better. If none of the above things work, check that the grounds within the car are good, battery to frame, to engine block and chassis. Sometimes a bad vehicle ground is the cause. If all else fails, hook it up to someone else's system and see how it works.
SOURCE: jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
