Question about Microwave Ovens
GE model JVM1340WW002 My microwave was working and stopped in the middle of cooking. Timer works, but fan does not blow and turntable does not turn.
  • Microwave Ovens Master
  • 9,098 Answers
I would say this is is a problem with the bottom door switch.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There also should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 24, 2008
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Sep 11, 2009 | GE JVM1750SMSS Microwave Oven
GE Microwave Doesn't Work, Timer Ok
More than sure, the door micro switches do not work properly, they should be carefully checked.
Sep 24, 2017 | General Electric Microwave Oven
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 06, 2007 | GE JVM1542 Microwave Oven
Microwave Ovens Logo
326 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
