Question about Gateway FPD2275W LCD Monitor
Aoc 19mvwk black screen
My monitor has a black screen, and the power light flashes. Can anyone help me? Thanks, Brandon
  • roy_henry Aug 24, 2008
    I have a HP p1100 21 Crt . Was working fine for a long time.
    Now when I power it up You can hear it trying to switch on but after 20 seconds the power light turns orange and keeps flashing.. Dead screen
  • 876 Answers
For your AOC here is a link that may help you:
and here is the other link they refer to on the first:
The following link from HP may help both of you:
Posted on Aug 24, 2008
  • morans200 Dec 29, 2010
    Actually, I had the same problem. It's probably one of two things: 1) Set your Power Saving mode for the monitor to "NEVER" turn off automatically. 2) Sometimes if its an Energy Star model (probably is), it can't be plugged into an outlet with a lot of other stuff. 3) Try unplugging from current outlet to another one and also disconnect VGA cable. Then plug back VGA cable and replug into new outlet.
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
I have an AOC 19MVWk monitor with a flashing blue power light and the screen isn't on. What does this light indicate? Thanks
It does the same when attached to another PC? It may be indicating that it is in safety shutdown/restart mode due to shorted or failed circuits in the power supply due to bad caps or in the backlights inverter circuits, you need to open it up and inspect the inside and circuits.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 15, 2011 | AOC 19LVWK LCD Monitor
My 19mvwk is saying no signal going to sleep
Check the data cable is properly fixed. Can you hear the beep sound while booting. Check the ram inside the cpu.
Jul 06, 2009 | AOC 19LVWK LCD Monitor
AOC 7 F 17" the OSD keeps on flashing
Aug 03, 2008 | AOC 7F 17" CRT Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Problem with the risolution
To my understanding, an AOC LM729 is capable of 1280 x 1024 and therefore should be able to display your preferred 1024x768 .
Perhaps you need to set the PC's Display Screen Refresh Rate to 75 Hz or lower (DisplayProperties/Settings/Advanced/Monitor).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 14, 2008 | AOC LM729 17" LCD Monitor
AOC 19MVWK - no image or rainbow vertical lines
It seams like connection is bad. If it is black but light show that is on or in stand by than it is the cable from monitor to computer if monitor is totally off when it is black either the electrical connection is bad or the power plug is broken.
Jan 31, 2008 | AOC 19LVWK LCD Monitor
Gateway FPD2275W LCD Monitor Logo
544 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
