Question about ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...
No network connection
Hi i have a problem with my asus motherboard. My board wont connect to the newtork. I even try installing a new nic card installed the proper driver and check the cables and i't wont detect the network. even thoug the cable is connected the notify icon on the task bar says a local area connection is unplug. is my motherboard needs a new replacement will someone help me how to resolve my problem!!! thank you in advance...
  • 781 Answers
Did you setup your network connection
Go to control panel network setup and follow instructions make sure both computers are on the same network
EG : network name = workgroups or similar
And also is your router setup properly
Posted on Aug 25, 2008
Monitor connection
Hi:
You need to install a Graphics card , because this board does not have on board video!
Apr 29, 2010 | ASUS P5PE-VM Motherboard
The on board ethernet adapters were damaged so i purchased an ethernet card Realtek 10/100/1000 however it gives me internet for all of 30 seconds until i try to access a website then it dies and loses...
There shouldn't be any issues if the network connection worked with the integrated NIC. Maybe you just managed to purchase a defective replacement card. The other possibility is that you didn't disable the onboard network hardware in the computer BIOS settings. There may be some conflicts since the motherboard is trying to address both of them. Make sure the onboard NIC is disabled, and try another PCI card if you still have problems.
Apr 14, 2010 | ASUS A8N-SLI Premium Motherboard
New motherboard makes my wireless nic loose signal.
It sounds like a driver issue.
I assume you mean the card worked previously on an old motherboard.
Remove the wireless NIC driver and then re-install it. I assume their are no yellow exclamation marks agianst your NIC in windows system properties? To see sys properties right-click "My Computer" select Properties/Hardware/Device Manager. Look for the network adaptors section. You can update drivers from here on your wirless card or even try the Troubleshooter tab.
if you don't have the driver CD let windows go onto the internet and search for a driver.
If you rely on the wireless card to connect to your internet connection, perhaps you can connect your computer to the internet modem or router via your computers LAN/network connection?
If that's not possible, download the driver from the NIC cards manufacturer website and pop it onto a USB thumb drive which can then be installed onto your new computer.
Last thought, make sure you are only using one controlling application for your NIC ie you use either the Windows Zero Config Utility OR the NIC cards manufacturer utily eg D-Link, Netcomm, etc etc
That is not both at once as windows has a major hissy fit.
See:
http://forums.whirlpool.net.au/forum-replies-archive.cfm/438290.html
http://www.netcomm.com.au/__data/assets/pdf_file/0020/17291/61_Using.pdf
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1378157.html
Cheers,
Steve
Mar 07, 2010 | Abit AV8 Motherboard
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
What are the two ethernet for? Does it let you plug in both and you can use both at the same time, therefore downloading faster than one or something?
No you can't download any faster with 2 NIC ports.
In a typical setup where a PC has 2 NICs, one is setup as the connection to the internet and the other can be used to interface with any device that is Ethernet capable (home video cameras, alarm systems, home control systems, etc). However, the other NIC can be connected to another network.
You can even share an internet connection though a wall NIC throughout the home.
This means 1 for the internet and the other for networking to another hub/server or computer.
Regards.
Nov 13, 2009 | ASUS A8N-SLI Premium Motherboard
When installing this card it has 26 pin conector at the top where do you connect on the mother board or somewhere else . The motherboard is an ASUS 3PV 4X
Hi!
Onboard you have 6 white connectors, those are PCI connectors, you also have ONE BROWN connector, thats the VGA connector
http://www.thg.ru/mainboard/20000302/images/p3v4x.jpg
You connect your vga-card on that brown connector (if it fits)
Good luck
Nic
Mar 28, 2009 | 3dfx Computers & Internet
No internet sites reachable, nothing appears to be wrong
Have you set it up for network through windows network setup
also check network name the same (I had one that i thought was correct and one letter in network name was different and would not connect)
Nov 19, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Can I add a NIC card to my compaq presario pc sr5250nx? I keep loosing my internet connection every five minutes and have to reboot the computer to reconnect
you should be able to
http://h10032.www1.hp.com/ctg/Manual/c00840496.pdf
if your system is still within warranty I would think twice about opening the case yourself to installing a new network card.. you will be voiding your warranty.. so think about it
another thing i would try before deciding on going for another network card is to check your onboard network adapter has updated drivers... or you may want to reinstall the drivers for that adapter.. either one of those may probably fix your issue assuming is not a hardware failing given that your system may not be that old.... make sure you check the windows update and look for any new hardware driver for your network adapter that may be avaliable through windows update.
before you install your new network pci card you may have/want to disable the one on board going into your bios for that. so to ensure there's no resource conflicts when installing the driver for your new card (it may not be a problem even if you don't but if you run into problems while installing the new card consider this suggestion)
Oct 02, 2008 | Compaq Computers & Internet
ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
Problem with the LAN Ethernet NVIDIA
right click on taskbar network icon and click disable
Mar 13, 2008 | ASUS P5N-E SLI Motherboard
ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...  Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
