Can't turn my camera on it was workin last night. i changed the batteries because i have the rechargeable ones and i thought that was the problem. i need some assist. asap.
  • 2 more comments
  • esmeralda_11 Aug 30, 2008
    same problem.every time i try to turn camera on,nothing at all happens
  • ankit1606 Oct 09, 2008
    same issue. If i switch on the camera feature... there is only blank screen. The capture key doestnot work.
  • Anonymous Jan 19, 2009
    No respons on camera, after hard-reset the icon og camera om programs is gone.
  • Anonymous Mar 22, 2009
    my camera not working plz help:S
Same problem :((
Posted on Aug 30, 2008
Sir, i have nokia 5230 and airtel gprs connection (recharched 2 week ago). 1. from last one day, WHEN I CONNECT NET THERE IS ERROR OCCURED PACKET DATA CONNECTION NOT AVAILABLE. select connection (no...
Pls recharge your airtel no: with suitable GPRS plan.Go to SETTINGS>CONNECTIVITY>DESTINATIONS>INTERNET>CHOOSE YOUR AIRTEL GPRS SETTIN>[eg:mobile office]>create packet data connection> pls edit your homepage as http://www.google.com and ACCESS POINT NAME as airtelgprs.com>AUTHENTICATION as normal>and USE ACCESS POINT AS automatically.[YOU KNOW WHY YOU CANT USE GPRS IN NIGHT.SOME TIMES YOUR ONE OF THIS SETTIN WILL BE CHANGE {use access point automaticall changes to after confirmation thats why you cannot use GPRS}]. AND IN THE MAIN WEB BROWSER >SETTINGS>GENERAL>INTERNET AS UR DEFAULT...AND IS THERE ANY PROBLEM CONNECTIN DO THE SETTING. AND IF YOU DONT CONNECT SWITCH OFF AN ON TO REFRESH YOUR PHONE
May 20, 2011 | Nokia 5230 Cell Phone
Tip
Digital Camera Problem - Shutting Off - Lens Not Retracting ?
If your digital camera shuts off sporadically or begins to malfunction, the fix could be as simple as replacing your batteries!
I was using AA rechargeable batteries when my camera starting acting up. My husband suggested that the batteries might be bad. While they were not new, they had only taken about 20 recharges over the years. I mistakenly thought they'd last for hundreds of charges despite age. As it turns out, rechargeable batteries have a shelf life.
Also, I had been storing my rechargeable batteries in the camera between uses. Remember, it is wise to remove any type of battery from the device if it will not be used for an extended period. This should help to extend the life cycle of your batteries.
Result: Upon installation of new, freshly-charged rechargeable batteries, my camera worked perfectly.
on Jun 19, 2010 | Cameras
Won't come on. I have replaced batteries a
So, you have purchased 100 batteries and none of them worked! Now you have spent $15 on rechargeable ones and they didn't work either. At $.50 a battery and adding the rechargeable ones, you've spent $65 on batteries and you still "love this camera"? I think your daughter deserves something better. So do you.
Jun 04, 2010 | Sony Cyber-Shot DSC-U10 Digital Camera
My camera won't turn on, changing the batteries/cleaning the contacts hasn't helped. It was fine last night, and i can't see how it would've been knocked or damaged, i was careful!
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 17, 2010 | Kodak EasyShare C140 Digital Camera
I just bought my camera and the batery ran out,
get rechargable batteries and a charger, you will not have that happen near as often, regular batteries do not last long at all a few pics kills them. rechargable batteries last much much longer and you just recharge them over night, pop back in.. sum other batteries don't hold a charge, may try it in something else, see if its bad
Sep 28, 2009 | GE Cameras
My charger is not working since morning. it was well and good last night.
What do u mean it's not working...??
Check for any loose connections...
It's a laptop charger, and u said it was workin' fine last night, then there's bound to be a loose connection......
If nothing else [like thunderstorms, voltage fluctuations, or any other harmful incidents] hasn't occured, it's connection prob....
Try using different plug-points.... Try checking the adapter if it's correctly connected or not...... If none of this works, call a comp spec.....!!
Jul 08, 2009 | Computers & Internet
Wont turn on
My camera worked fine last night while I was taking pictures, however, I couldn't get it to power up today so that I could upload my pictures. I spent half the day recharging batteries, buying new batteries, and searching the Internet for solutions.
It turns out that I just needed to switch the batteries around. The positive and negative battery chambers are mislabeled in my camera. Duh! Works fine now.
Hope this helps someone.
Mar 30, 2009 | Kodak EasyShare C613 Digital Camera
My Jazz Dv179 Digital Camcorder Won't recharge
The battery in the camera is likely not a rechargable one. Check the print on the battery. Mine was not so I assume your is not as well. The maker of the camera was pretty cheap not supplying a rechargable battery, for the price they ask for the camera.
Dec 29, 2008 | Jazz DV-179 Digital Camera
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Computers & Internet Logo
David Payne
David Payne
