Question about Intel Motherboard
BIOS for SE440BX-2 Mothermoard
My BIOS written by Phoenix for Intel motherboard of SE440BX-2 Motherboard has been corrupted while I was up-grading my OS from WINDOWS 98 to WINDOWS XP. How can I restore I mean reload the BIOS. Please mention the web-site from where I may download the BIOS. State the procedure to Load the BIOS.
Thanks
Mohd. Ansar ALI
  • 781 Answers
How do you mean corrupted is it because windows will not start or upgrade
I would say your BIOS is Ok
you just have to try to reinstall windows but use full version not an upgrade one
Posted on Aug 24, 2008
I want to upgrade the cpu on a se440bx-2 slot 1 PIII motherboard
If you go to www.motherboards.org and type in your motherboard, it will find it and give you all the information that you need.
Nov 08, 2009 | Cornerstone INTEL SE440BX-2 SLOT 1 PIII...
I have a corrupted BIOS (Intel 440BX motherboard) with Phoenix bios 4 release 6 (release no. 4S4.EB0X1.86A. 0011.P04). Cannot find the correct bios software to rectify the problem (even the bios software...
Hi, Read this information it might help you. Go to this web site www.hardwaresecrets.com/article/39/2 I hope this information will help you solve you bios problem.
Aug 17, 2009 | Computers & Internet
Sound Problem for SE440BX-2 in XP OS
You can download the driver here :
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=208&DwnldID=3522&lang=eng
Mar 20, 2009 | Intel Desktop Board SE440BX-2 Motherboard
I have an intel SE440BX-2 that does not recognize my mouse and keyboard. The scroll lock, num lock, and caps lock all flash repeatedly. The keyboard and mouse do not work at all. Tried 2 different hard...
hi im josh in cebu.friend if it wnt detect the probem is on your bios setup or on your motherboard parts like the cmos batt. you go to bios setup then go to pheriperals then choose enabled keyboard and mouse. or try to remove your cmos batt then afterr several seconds.install back firmly and tightenly. then reboot your pc.this will help you a lot good luck
Feb 23, 2009 | Intel Desktop Board SE440BX-2 Motherboard
SE440BX-2 BASEBOARD-WANT TO INCREASE HARD DRIVE SIZE.
You may need to update the BIOS. When first booting press F2 to enter your current bios. The latest bios for your motherboard is version P17. Also if you see a number with an "86A" in it, the number after that number should be "0024". The bios dated 9/1/2000 is the latest version.
If you decide to update the bios, be _very careful_ to follow all instructions exactly, otherwise you can render your computer useless.
While you are in the bios, and before you try updating the BIOS, check your IDE configuration to make sure that the IDE controller is set to "both." Also in the primary IDE master submenu, be sure that "LBA Mode Control" is set to "enabled." When exiting the bios, if you made any changes described above, be sure to select "save on exit" or similar. Re-boot and try the new drive.
Here's the update website from *********** board.
http://www.intel.com/support/motherboards/desktop/se440bx2/
Jan 26, 2009 | Intel Desktop Board SE440BX-2 Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Board won't boot up.
Please tell if the power indicators are light up on CPU front and on Motherboard.. What happen when you press the power button... is there any beep...
May 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
yes, i think that this will be optimal. rember after some dvd burn to
defrag your hard disk
Sergio
Mar 14, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Intel Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
