Question about Epson Stylus CX3200 All-In-One InkJet Printer
Still looking for Smart-Scan software
MadBindus has lead me to the Epson site - but no sign of Smart-Scan software there. I had successfully loaded Twain and Printer drivers before - but pressing the scan button leads me to a near-useless window offering three ill-chosen applications to use for the scan. I get a much better facility via the twain souce in Paintshop Pro.
Where is that elusive Smart-Scan software??
Alternatively, how do I get PSP to be a selectable item in the pop-up list when I press the scan button?
  • leeford Aug 24, 2008
    Thanks MB - just to confirm it is CX3200.
    I have been to properties/events before - the only applications offered are
    Canon CameraWindow
    ACDSee 7.0
    I can't find where this list is stored (I've looked in the registry)
    Thanks MadBindus
    From your comments, I think I'm as close as I'm going to get - which is to initiate the scan from Paintshop Pro - which is where I want the scan anyway (except on the rare OCR occasions).
    Works fine from there. I might as well disable the scan button on the machine (via properties/events).
    Thanks for all your help. Bob
  • 110 Answers
You can program the scan button by going to "Control Panel" and "Scanner's and Camera's.
Right Click the scanner and go to "Properties"
Select the "Events" tab
It should allow you to program your one touch button from here. I just wanna verify that you do have the CX3200 and not a Stylus Scan 2500?
Posted on Aug 23, 2008
  • Mark Simpson Aug 24, 2008
    As you already know, you do not the need the Smart Panel (smart scan) to actually use the scanner. The Bonus Software called smart panel (options include "Scan and Save, Scan to .Application, Scan to email, Copy utlity etc." is actually made by a company called Newsoft ( You would most likely have to purchars that program from them as i have never seen it as a free down load.
    If your program is not showing up in the events tab, forget about that method... no mayyer what u do it will not show up there.... trust me.
    But, please explain to me exactly how it used to be, step by step, when u used to scan and all was good. I may be able to figure a simple solution for you.
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page.
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
I cannot scan to windows xp from epson rx425 all in one printer
First switch off printer & uninstall everything including the printer drivers. Download the latest software from Epson Support site & reinstall. Link:
Jan 28, 2009 | Epson Stylus RX425 Multifunction...
need to check for an update - go first to
second place to look for updates is from the software manufacturer (yes it says EPSON Smart Panel but it is a bundled application)
Sep 09, 2008 | Office Equipment & Supplies
Software refuses to open
Here is your fix
and for the person getting "Epson scan cannot be started. That is a comm error. Check your connections and rinstall the software. Do not attempt the following
1. Click on START and then RUN.
2. In the Run window type in REGEDIT.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look in the column on the left and Click on the “+” sign next to HKEY_CURRENT_USER
9. Click on the “+” sign next to SOFTWARE
10. Click on the “+” sign next to Epson
11. Look for a folder name EPSON SCAN. Right click on it and Delete it
Feb 07, 2008 | Epson Perfection V100 Flatbed Scanner
Epson stylus PHOTO RX425
Epson has software called "Epson smart panel" and you can select scan from the list of operations.
Turn your scanner on, (windows OS) click on "start" then click on "all programs", look for epson smart panel in programs list, click and let panel load, then select scan.
It will take some time for the scanner to warm and scan, so be patient, after it is scanned your options are to print, or save. If you save, be sure you know where its filed or "tell" it where to save, I recommend creating a new folder before in "your pictures" titled "scans" . Usually after you do this, it will save it there by default.
Dec 09, 2007 | Epson Stylus RX425 Multifunction...
Can't get it to scan
1. Make sure the shipping lock on the scanner is free see- set up sheet. 2. Remove all Epson software relating to this device. 3. ReBoot. 4. make sure you are off line. 5. Fully disable any Anti Virus software Switch off the unit and disconnect the USB cord 7. Now install the software and follow the EPSON steps exactly -take no shortcuts
Jun 08, 2007 | Epson Stylus Photo RX500 Printer
Help on sending email from my printer Above is the Epson site and your model. Download the latest drivers and software and you should be able to email pictures fine. Good Luck, Tim
Feb 10, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
430 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
