Question about Denon AVR-4308CI Receiver
DENON AVR 4308CI
I JUST HAD MY AVR 4308CI INSTALLED BUT I STILL NEED AN -EXPERT- TECHNCIAN ON THE PARTICULAR AVR TO HELP ME GET SET UP AND GOING.
PARTICULAR PROBLEM GETTING THE FM RADIO GOIND......SELECTING AND ENTERING FM STATION ETC....ETC..
HELP.
CAN YOU HELP? WHAT IS YOUR HOURLY RATE AND DO YOU TAKE CREDIT CARDS?
GILBERT P YSAIS
ARLINGTON, VA BALLSTON AREA
SORRY, I WANT HANDS-ON SERVICE HERE IN MY CONDO.
Posted on Aug 24, 2008
My DENON AVR-4308CI HOME has no sound. Everything comes on as it should and unit looks great but no audio comes out. It's had off and on issues since I bought it, but firmware helped with some. Now, no...
This may require quite a bit more info. Verify that there are no shorts in the speaker connections to the Denon - it has a short detection circuit that will shut down the audio amps in the event of a short. If you are using optical or coaxial digital input for you audio - verify that the correct digital input has been assigned to the component selected on the Source Select dial: Menu > Source Select > Assign > Digital. If this is an HDMI connection go into the HDMI setup menu and select Audio: AMP: Menu > Manual Setup > HDMI Setup > Audio > AMP. If it is set to TV the audio passes through the AMP without being decoded and goes to the TV instead: there is no 'Both' setting.
Oct 26, 2013 | Denon AVR-4308CI Receiver
Is there anyplace that has denon schematics listed for free. I need them for models, AVR-4308CI & AVR-2307CI. Thanks, Lynne
send me your email address to www.yam_man_dan@yahoo.com and will email you them tomorrow,, put in title models make required to avoid spam..regards..yammandan.. have all teac denon yamaha manuals...regards yammandan
Aug 19, 2010 | Denon AVR4308CI
Sound went out today. Mute is not on, and all
Does it think you have headphones connected? If you have headphones, check to see if they have sound output.
Jan 26, 2010 | Denon AVR-4308CI Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Were can I download a swedish manual for Denon AVR 4308
HI,
This was the closest could get on the user manual for this device.
http://www.denon.co.uk/site/popup/index.php?p=pdf&Pid=340
Thanks
proton
Aug 02, 2009 | Denon AVR-4308CI Receiver
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
Jan 19, 2009 | Denon AVR-3300 Receiver
115v home cinema in 220v area
If it dosn't have a switch on the back to run in 220 I thought it did ??
then you will have to use one of those huge transformers they have over there and run it at 120
May 09, 2008 | Denon AVR-4308CI Receiver
Denon 4308CI power
Tienes un problema con los amplificadores de audio de tu aparato.
Mar 17, 2008 | Denon AVR-4308CI Receiver
On screen display does not appear
Same problem, thanks for the solution -- resetting power solved it.
Mar 02, 2008 | Denon AVR-4308CI Receiver
Denon AVR-4308CI Receiver Logo
196 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
