Question about HP Photosmart 3210 All-In-One InkJet Printer
HP photosmart 3210 - power does not come on
Hi, My all-in-one won't turn on. The power cord is not the problem. Is there a fuse inside that could have blown? Any other suggestions?
Lisa
5 Suggested Answers
SOURCE: out of paper:
I unplugged the printer and took the back cover off and cleaned all rollers using rubbing alcohol and q-tips. I also used canned dust remover and sprayed all parts. This took care of the no paper in tray issue for me!
Posted on Apr 07, 2008
  • 136 Answers
SOURCE: hp photosmart 3210 vista drivers
just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
thanks.
Posted on Oct 13, 2008
SOURCE: HP 3210 black ink problem
Mine failed too within the last week, nothing will print using Black. Bought the printer April 2006. HOWEVER, I HAVE FIXED IT!!!
Assuming that I had nothing to loose, I took a kids Calpol 5ml syringe and half filled it with Boot Nail Polish Remover, and injected it into the lower ink feed nozzle that protrudes when you remove the cartridge.
The syringe tightly fits the nozzle so that when pushing the plunger, a good deal of pressure is felt and you can force the fluid into the pipes/print head. Any that gets split inside the printer will evapourate near enough instantly and of course being a thinner, it dissolves ink and any bloackages.
I turned on my printer, printed a test page, and low and behold the black started working again!!! Just waiting to see how long my solution lasts me.
Martin
Posted on Nov 05, 2008
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
How can i resolve an hp 3210 error 0xc18a0206?.
try this it worked for me unplug power cord from printer and electrical outlet wait 30 seconds hold in help and ok buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me
Apr 25, 2016 | HP Photosmart 3210 All-in-One Printer...
My Photosmart 3210 shows the failure code 0xc18a0206 and nothing works. I have tired to reinstall the software from HP but it did not solve the problem.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Mar 20, 2011 | HP Photosmart 3210 All-In-One InkJet...
Keeps saying carriage jam but don't see a jam. was on earlier carlesann@yahoo.com
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Aug 25, 2010 | HP Photosmart 3210 Printer
Inksystem failure
Hi ,
please follow the steps metnitioned below:\
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved if not then you need to service the printer. all the best
May 06, 2010 | HP Photosmart 3210 Printer
Hp3210 ink system failure
Turn off the machine, unplug the power cord from the back of the machine, remove ink cartridges, wait 2 min, plug power cord back in, press on button, wait until the printer prompts you to replace the missing ink cartridges, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the lines. There are instructions for doing this at www.ccl-la.com/blog/. Search for HP Photosmart and run through the "ink system failure" #1 instructions.
Mar 07, 2010 | HP Photosmart 3210 Printer
Ink system failure
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, turn the machine on using the power button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
PRINTER IS PLUGGED IN, BUT DOESNT TURN ON?
Try a different known working outlet..If you still don't have any lights then try a different power cord. If there is still no power then the printer is bad. With all the storms we have had going on it could be a bad main board or blown caps or onboard fuses.
Jun 17, 2009 | HP Photosmart 3210 All-In-One InkJet...
Reset the product:
  5. Wait 60 seconds.
Thanks, Joe
May 05, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
