Question about Linksys WUSB54GS 802.11G USB Adapter Wireless-G With SpeedBooster (Retail) (NTUSLSUSB54G)
Linksys Wireless G USB Adapter does not connect to the Internet
Hi, I just recently bought a Linksys Wireless G USB Adapter to connect wirelessly but it does not work. I am running Windows 2000 (SP4) and it says on the box that it is compatible. It shows that it is connected to my home network by displaying the name and the signal strength but when I open up a window in IE, it just does not work. Can someone please help me? I have tried the same network adapter on an XP laptop and it does work OK. Thanks
  • Aguila-Uno Sep 08, 2008
    Thanks for your response.
    I am not an expert on this so I apologise if my response is a little vague (but I will do my best !)
    1st thing is saw is that my IP address on the win2000 pc is: 89.217.147.31. Then, it says that my LAN is 192.168.1.1 on the modem settings. Also, if I am not mistaken, Linksys told me to config. the router to 10.10.10.101. So I am a little confused.
    My DHCP is enabled.
    If I connect the ethernet cable directly to the comp., it works. Only the wireless USB doesn't seem to work.
    Lastly, when I try to release the ipconfig, it says that the WAN (Wireless Connection) was automatically configured and does not currently have a DHCP address.
    Any ideas?
    Thanks again for your help
    Cheers
    Aguila-Uno
  • Steve Rand
    Steve Rand May 11, 2010
    What are your IP address settings?
    Are you running DHCP on the router? If so, is your win2000 box obtaining a valid IP?
    Are you able to ping the router over wireless when you have no WAN connectivity?
    Does your win2000 box connect via the router over ethernet normally?
  • 59 Answers
Well do on ething first .... when u try to connect to the network ....
there would be an advanced option there or in short it would be an option for removing the prefered networks .....
remove every prefered network from there ....
Posted on Nov 27, 2008
Linksys Wireless Adapter that will not find the internet
I think you might be using the Linksys utility.
you can switch over to windows utility if it is XP or VISTA.
that will resolve the problem.
make sure that it will be connected to the network and should have proper IP address
Click Here for more info about wireless network set up
Oct 12, 2009 | Linksys Ultra RangePlus Dual-Band...
Netgear wg111 - I am connected to wireless network
i have seen issues with wireless USB adapters. Can you try another USB port on the computer? Also delete the adapter and let it br reinstalled. If this does not help, I would suggest returning it and getting a Linksys adapeter.
Jun 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Unable to connect to internet with usb adapter from Linksys.
hi pinkpiggly,
thanks for using fixya.
I have prepared a document for you to check on on getting you wireless Linksys adapter to connect to a wireless network.
Wireless Connection Problems Setting up your Linksys router to have wireless security Hope this helps.
Regards,
voodoo
May 11, 2009 | Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Do i have to have a linksys router to be able to use usb adapter?
No you do not, but you do need some form of a wireless router to make that Internet connection wireless. Depending on which modem you have that connects to the Internet, you might already have a wireless router.
Feb 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Internet explorer won't open
when it says connected it means to the router, open up internet explorer>tools>internet options>connections tab and tick never dial a connection, or if it's already greyed out it's ok.
Assuming you have run the wireless network connection wizard first to set up the connection, if not it's in network connections and select new wireless connection or set up a wireless network.
Sep 24, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Jul 25, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Linksey wireless-g usb adapter and router
lose internet connection from my second computer that is linked to main computer (main computer has internet connection). Tried to click repair and it said couldn't be repaired contact internet provider?
Nov 01, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Computers & Internet Logo
327 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
