Question about Intel Motherboard
Monitor won`t turn on
I`ve checked proc, grafic card, power supply and RAM`s and stil wont work.
Wright now i dont have another motherboard here to check out if that`s the problem. Could there be another trick?
It may sound weird but check that the motherboard battery cell is charged (the CR2032 coin battery). Some motherboards wouldn't power on if the battery is completely empty. Also clear the system setup via the jumpers on the board.
Try booting up with no graphic card installed and using the onboard graphics (if the board has a onboard GPU).
Posted on Aug 23, 2008
My system won't boot but there is power
The things to check when your system will not post are RAM (make sure it is in all the way) Hard Drive (make sure it is properly connected) Your CD/DVD drives (again check connection) and your video connection (if you have onboard graphics, this may not apply, if you have a seperate video card make sure it's properly secured in the PCI slot)
Once you've checked all of these things, if you still have a problem, listen for the beeps that come from your computer's motherboard and remember the order of short and long beeps. Respond with the beep sequence and type of computer you are using.
Jun 01, 2012 | Gigabyte GA-G41M-ES2L Motherboard
Hi! i am having problem with Display from motherboard. I had already checked ram, power supply but i didn't get any display. so how can i resolved this problem. Please help.....
I'm assuming this is a desktop motherboard? Make sure the plug for power is connected and tight. It is refuses to work see if you have another slot and try moving it to the free spot.
If it still doesn't work: 1. make sure your monitor is connected properly and turned on 2. if possible try the monitor on another machine to make sure it's not the monitor itself
If the monitor works correctly on something else and you've tried the above than it's likely that the video card itself died and needs replacing.
Aug 08, 2011 | Computers & Internet
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
P25g motherboard, monitor wont turn over
i think you need to try replace you're ATX power Supply or you need to try remove the other 1 of you`re memory...Thanks
Apr 23, 2009 | PC Chips P25G Motherboard
L7vmm mb. display went out. Monitor works on
Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
Apr 17, 2009 | Computers & Internet
EliteGroup ECS AMD690GM-M2
get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years i right?)
UDIN (indonesia)
Jun 13, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
Monitor problem
Sounds like your video card is failing. If you get video directly from the motherboard then you may need to replace it.
May 09, 2017 | HP Pavilion MX90 19" CRT Monitor
Dfi wt70ec socket 423 board never used and visiontekx1300512mb agp
Either video adapter is not seated properly. Remove the video card & reseat.
Also, check to ensure the monitor cable is connected properly.
Jan 01, 2008 | DFI NT70-SC Motherboard
Intel Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
