Question about HP DeskJet 1280 InkJet Printer
HP DESKJET 1280
Yes, it shuts off when i turn it on and it only lasts for a second (WHEN I PRESS THE LIGHT TURNS GREEN BUT AFTER A SECOND IT SHUTS OFF)
  • 2 more comments
  • Anonymous Sep 05, 2008
    yep same here
  • friendlyjohn Mar 04, 2009
    sim as him.win i power un the power buttun, it unle lights poor a see kands then it shuts off. is deer eni juan ho can sulve this problem?
  • Anonymous Apr 14, 2009
    my printer keeps shutting down after a couple of seconds.
  • systemadm402 Apr 20, 2009
    Not able to Power on the HP Deskjet printer 1280. When I press the power button, it blow green light and in a second it goes off? please help
I had this problem too and found that the rear cover (the one that you remove to clear a paper jam) was not correctly fitted and locked. After resetting the vover and fully locking it worked! Try it.
Posted on May 02, 2009
6ya staff
SOURCE:
Panasonic Plasma TC-50PU54 LF21030116 Power light blinks 8 times When I attempt to power on it turns on for split second then shuts down. Is this fixable? thanks.
Yes. It is probably a problem with the internal power circuitry. Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Panasonic Televison & Video
MY PS3 wont start up, everytime i press the start up button it turns green for a second and then quickly turns yellow and shuts off
That yellow light is what us gamers refer to as YLOD.. Its the Yellow Light Of Death. Your system will have to be serviced by Sony. If your system is under warranty still it wont cost you anything but if its not, Sony charges 150.00 dollars to fix/replace it. They will send you a box in the mail to send it to them. Turnovers usually 2-3 weeks. My condolences to you and your PS3. Best of luck to you.
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turns on for less than a second. then shuts off
Unplug fo a .5 hour let it reset then see what happens when I got mine to fire up the blue side to side convergane wouldnt adjust GOOD LUCK
Jun 13, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Ps3 console turns on then off
hi puede sumali sa promo nyo ?kung puede lang poe
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Lense not closing, switching on for one second then shuts down. when attempting to turn on green light flashes then turns off
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Canon Cameras
HP DeskJet 1280 InkJet Printer Logo
529 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
