Question about Brother HL 1450 Laser Printer
Brother network printer shows tcp/ip disabled
I have a hl-2170w and can not see it on the network (works fine from usb)
    Scholar:
  • 105 Answers
Download the software/driver package from Brother and do a clean install. You have to set it up first (best to do using LAN/wired connection initially).
Posted on Mar 04, 2009
I fixed the drum and error light but i still can't print
http://mycomputerbytes.wordpress.com/2011/11/16/reset-brother-hl-2170w-network-settings/
If printing via network and you have not set a static (meaning it doesn't change) ip setting for your printer, then your ip address may have changed. IF this is the case, http://mikebeach.org/2011/03/02/assigning-the-brother-hl-2170w-a-static-ip-address/
Also, have you updated your printer driver? Be sure to go to control panel, device manager, printer, and then uninstall before installing new driver. Also, uninstall/remove the printer.
http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hl2170w_all
Hope this helps.
Jun 03, 2014 | Brother HL-2170W Laser Printer
Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Jun 23, 2010 | Brother HL-2170W Laser Printer
HL-2170w won't print with Windows 7
Windows 7 will not work with earlier Windows versions of printers
Feb 28, 2017 | Brother HL-2170W Laser Printer
HOW DO I CHANGE THE NETWORK IP ADDRESS AFTER INSTALLING?
This link should take you to the .PDF manual for changing IP addresses on your Brother HL 2170W Laser Printer. Refer to page 10 and 11. Use it to guide you through the steps.
It will ask you to use your Printer CD that was supplied with the machine to install and run the BRAdmin utility. If you do not have the CD, you can download the utility here.
I hope this helps you with your question. Thanks for choosing FixYa.com
Apr 19, 2010 | Brother HL-2170W Laser Printer
We just got two brother hl 2170w printers from a lab across campus, they were configured for a wireless connection and now we are trying to connect them to the network via a wired connection. the test page...
hi there, this should work for you:
When you disconnect an Ethernet cable from the printer, wireless network will be enabled.
On the other hand, when the Ethernet cable is connected to the printer, wired network is enabled.
If you press the Go button for approx. 13 seconds, the network setting page will be printed out. Then release the Go button, wired network will be switched to wireless network even if the Ethernet cable is still connected.
You can then verify your network settings and change between wired and wireless setups.
Apr 16, 2010 | Brother HL-2170W Laser Printer
IP address
If you lose the IP address you can reset the network card.
Since the machine no longer has an IP address, you MUST be connected with a network cable.
1. Turn the power off
2. Press and hold the "go" button (the blue one on the front)
3. While holding the Go button, turn the power back on.
4. Keep holding the Go button until all 4 lights are on.
5. Release the "Go" button and press it 7 times quickly.
This will reset the network card and you should get a proper wired LAN IP address.
Thanks,
Pat
Mar 31, 2010 | Brother HL-2170W Laser Printer
Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Jan 26, 2010 | Brother HL-2170W Mono Laser Printer
Lost cd-rom for brother HL-2170W. I need to connect a new laptop to the printer on my wireless network and can't figure out how to do it! It's running Windows XP Pro.
Download the updated firmware, drivers and software for you printer from here (select 'ALL' as Type, and then select your OS and language, to see all downloads available in one page):
Brother HL-2170W downloads Homepage
Also download the manual and guides for your printer:
Brother HL-2170W manuals
And make sure you also look through the FAQs and Troubleshooting under 'Initial Setup' and 'Software' sections:
Bother HL-2170W FAQs & troubleshooting
Sep 02, 2009 | Brother HL-2170W Laser Printer
Cannot print to 2170W via wireless
You need to hard coat your Ip for the printer.
Aug 29, 2009 | Brother HL-2170W Laser Printer
Brother HL-2170W Laser Printer is 'offline" wont turn back online
I have a lap top and was having the "printer offline" problem
1) I did the triple click on the printer as in soluyion two to get the IP address which is clearly labled on the 3rd page.
2) Clicked on "Devices and Printers" in the "Start" menu
3) Right clicked the "Brother..." icon and selected "Remove Device"
4) Selected "Add Printer" on the "Devices and Printers" menu
5) Selected "Add a wireless, network, or bluetooth printer"
Nothing was coming up in the search so...
6) Selected "The printer I want isn't listed"
7) Selected "Add a printer using TCP/IP address or host name"
8) Entered the IP adress from the 3rd page of the printout on to the line "Host name or IP address"
9) Left the "Query..." box selected, clicked "next" and printer installed
Jan 04, 2009 | Brother HL-2170W Laser Printer
Brother HL 1450 Laser Printer Logo
1,113 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
