Question about HP Office Equipment & Supplies
The paper constantly jams when printing or photocopying
    Master:
  • 848 Answers
There is some problem with your roller .......
Posted on Aug 23, 2008
  • gopinath pasupathy Aug 23, 2008
    Theres one paper sensor in the SX engine thats part of the fuser. On the PCB at the left side of the fuser there's a slotted opto-switch with a lever that detects paper in the fuser. There's also a single transistor on PCB that buffers/amplifies the output from the opto-switch, Q332, I think. This sensor must change state one way (to indicate paper has got to the fuser) shortly after the registration clutch operates and then change state the other way when the paper has got out of the fuser......
    Genius:
  • 1,847 Answers
Try clean the roller with little alcohol. Then try it will fine..
  • 435 Answers
Let me know your printer model
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Why is there a paper jam from cartridge?
There could be a hard-to-find shred of paper stuck inside. You may have to use a strong light and even do partial disassembly to locate the source of the jam.
Jul 27, 2015 | HP LaserJet 2727NFS All-In-One Printer
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Paper not going through and when it does it jams
Clean the entire printer of old paper, and bits and paper. You will be surprised how often a little piece of paper is stuck somewhere. Buy a bright LED torch, keep by printer ,so can check carefully.
Try a thinner paper, 70gsm. Thicker paper jams more often.
Buy fresh pack of paper. Paper gets wet. Old paper jams.
If older printer then the rollers might be dirty and sticky. Can use a cotton bud to wash with alcohol. Otherwise put your paper in a closed container and keep it dry. If damp/humid , then the paper gets sticky.
I am a finance whistleblower and have used some 10 printers and 1 10,000$ photocopier, all worn out. Sometimes just got to go buy a printer.
Buy the most cheapest printer. When it dies, go buy another. That way never loose money on big scan/print/fax dog printers. Use a local fax company and photocopy company - let them wear out their printers.
God bless John
May 04, 2011 | Office Equipment & Supplies
How to remove jam paper from photocopy machine
Hi there remove the front cover & side cover there you can find the jam papers. Just pull the paper & start printing. After that if you face same problem then check the paper trey & then turn off the machine for 5 minute & try. after that let me know the result.
Jan 18, 2011 | Canon imageCLASS D660 All-In-One Laser...
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
15 people viewed this question
Ben Johnson
