How to open a Maxtor haed drive case - Computers & Internet
  • Louis Davidson
    Louis Davidson May 11, 2010
    Why would you want to open a hard drive? What model#?
    Lou
    Novelist:
  • 210 Answers
Well, if it's for the purposes of making sure it will never work again, here we go...
They usually have screws that require a security bit, about 6 of them infact. You can use a flat-head screwdriver if it's long enough to reach two points of the hex-shape screw... then when they're all off, you can use a flathead screwdriver to pop the top silver cover off. After that, your hard disk is probably ruined forever.
Right about this point, I like to pull the magnets out of it (just because they're handy, and magnets are cool!)... then throw the disk in the bin.
That answers your question perfectly, but if you don't like the fact that there is no way of you opening your hard disk without spending $2000+ giving it to a professional company that have a 100% dust-free room, please don't rate my answer. Otherwise, feel free to give me full points! =-D
Posted on Aug 23, 2008
I cannot access my Maxtor external hard drive. My laptop will not start if the hard drive is attached. If I attach my hard drive after booting up my laptop the laptop freezes.
Your Maxtor HDD is Broken, or Jammed. thats why these hanging things happen. send it to the service center if you have any warrenty. i think they will fix this. if no warrenty then open the HDD casing and remove the HDD and put it in new casing and try backing up Date. best of luck...
Jan 26, 2011 | Maxtor Computers & Internet
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor One Touch 4 won't open
Hi, Generally one of three things will have happened, They damaged the cord, broke the connector inside the drive or they shorted the board by bending the connector. In the first case you can replace the AC adapter. In the other two cases it's not generally worth repairing due to cost. You can try locating a connector with the same voltage amperage and polarity to test the drive but you simplest solution in all three cases is simply to purchase a new enclosure at the local PC store and have the techs put the harddrive from the maxtor enclosure in the new case for testing(about $40). If this works you're done. If not the short may have damaged the cicuit board on the HDD. If the drive itself is damaged and you need the files that are on it you will need the help of a pro. Try the above suggestion and comment back here as to your results, if you need a pro, include your country and city in the comment and I will make an appropriate recommendation. Chris
Jun 05, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
How can I open the Maxtor Basics 500GB case??
See this link:
Mar 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Open up the case
Well, since you are discarding the case, use a small flat head screw driver or something to pry the case open. Once inside, the HD will be plugged in to a circuit board and screwed in place. Unscrew it and carefuly unplug the HD from the circuit board. Then you can transfer it to another external HD housing.
Jun 19, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Opening external drive case
Actual solution. The darker side panels pop off and they alone hold things together. Simply pry each side away at rear. That would be end with power and USB connections are.
Dec 10, 2007 | Maxtor Personal Storage 3000LS (G01J060)...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
