Question about Samsung SyncMaster 2253BW LCD Monitor
Trying to connect samsung 2253 bw lcd monitor to new computer
I am having problems connecting my new samsung 2253bw monitor to new computer
  • 4 Answers
Use the blue cable, make sure the screen is set to analog and the resolution on the pc should be at 1680 x 1050. check the pins in the cable at both ends for any bent or missing. do you have anymore information do you see anything come up on the screen?
Posted on Jan 09, 2009
Changed connections
Posted on Aug 24, 2008
SOURCE:
I set the resolution to 1920 X 1080 32 bit and when I reboot it reverts back 1028 X 768 at 16 bit
Hi
Please check u have install the right driver in your computer for the VGA, bcoz is my view your driver is not support that;s why it revert back. Install the correct driver and try again,
May 13, 2011 | Samsung SyncMaster 2253BW LCD Monitor
How to change aspect ratio?
change it by right clicking on the desktop and then selecting, in vista, personalize>display settings, or in xp, properties>screen resolution
Aug 06, 2010 | Samsung SyncMaster 2253BW LCD Monitor
When it is turned on the diplay shows for only a few seconds then the screen goes black turn it off and on and the same thing happens
Try another monitor on the computer and see if the screen stays on. If it does, then that means the original monitor is bad. If you get the same thing then its a problem with the computer.
At that point unseat and reseat the memory from the motherboard one stick at a time in each slot one at a time.
Then if that doesn't work, make surue only the power supply is connected to the motherboard and turn it on. If you still don't get video then you know the motherboard is shot.
Nov 28, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Samsung syncmaster 2253BW blurry/out of focus HELP!
cables wont make a difference, are you sure your display settings are set to 1680 x 1050? i have had problems when it is set to 1600 x 1000 and i had to reinstall the video card drivers.
Dec 28, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Flashing Off
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
Feb 08, 2018 | Samsung SyncMaster 2253BW LCD Monitor
Samsung SyncMaster 2253BW LCD Monitor Logo
323 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
