Question about Panasonic Home Theater System System
F61 i t was given to me by a freind it now has F61.....what is actually wrong to have it fixed cost more than what i paid for it ..its such agood machine until this happenened
  • 4,234 Answers
The F61 is a shorthand for protection mode. This means that a problem was detected and the unit shutdown to prevent further damage. If you can post the model number, I can provide the part number and cost.
Dan
Posted on Aug 25, 2008
How can I correct F61 error?
See page 37 of the user manual.
Get from lil given here.
Error F61
Check and correct the speaker cord connections. If this does not fix the problem, there is a power supply problem. Consult the dealer.
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Feb 01, 2016 | Panasonic SC-HT730 System
When i turn it on, it says F61
Given the error message, I'm going to guess that you have a Panasonic shelf unit with CD and cassette built in. If so, then the F61 means "protect" mode. This indicates that the unit has detected a problem in the final amplification stage and has shutdown. The fix for this is to replace the output amplifier pac and/or the regulator IC. If it is the amp-pac, expect a parts cost between $75 -$95.
Dan
Aug 29, 2009 | Panasonic Audio Players & Recorders
NEED TO AVERAGE CELLS, WHERE ONE OR MORE CELLS CONTAIN ''0'' OR ''#D
Try this. If any of the cells are zero (or blank), the word 'zero' will be displayed. Substitute anything you want for the text including blank ""
=IF(OR(F61=0,J61=0,N61=0),"zero",AVERAGE(F61,J61,N61))
Aug 26, 2009 | Microsoft Office Excel 2007
F61 error
The F61 error indicates that the unit is in "protect" mode. This means that an error condition was detected in the amp section and the unit has shutdown. This is usually caused by a defective amp chip. Expect a parts cost in the range of $60-$90.
Dan
Dec 05, 2008 | Panasonic SC-AK17 Shelf System
F61 in AK 600
There are a couple of possibilities:
1) The output amp-pac has failed and nneds to be replaced.
2) The power regulator pac is bad and nneds to be replaced.
Either option is somewhat expensive. Unfortunately without seeing the actual machine and taking measurements inside, there is no way for me to be sure what option fits here. I would take this to an authorized Panasonic repair center and have it repaired there. Expect a parts cost in the $50-$75 range.
Dan
Nov 28, 2008 | Audio Players & Recorders
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Panasonic sa-ht995 will not work ...... when turned on it says hello.......then f61 then turns off again how do i fix this problem?
F61 in the user manual says , check your speaker connections if ok then see your dealer, the reason f61 comes up is a amplifier fault , most likely a blown audio amplifier ic is faulty, and needs replaceing by a compenent electronic technician.
Jul 09, 2008 | Audio Players & Recorders
SA-HT680 F61 Error
Typically the F61 error is a protection error indicating that there is a problem with the output amplifier section. The failiing part is usually IC501 (part number RSN311W64D) which costs about $95. Have this unit checked as there are other possibilities.
Dan
May 05, 2008 | Panasonic Home Theater System System
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
Dec 14, 2007 | Panasonic SC-AK300 CD Shelf System
Panasonic Home Theater System System Logo
100 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
