MIL status is error codes, but usually for pre 1995 vehicles. If you check engine light was on, then it would not pass emmissions. Since your vehicle is a 2000, I would suggest you take it by an autoparts store and have them read your error codes before you try to reset them. Make sure you write them down in the order they come off their scanner.
Yu can usually clear error codes by disconnecting your battery.
There will likely be no noticeable symptoms along with this code other than the MIL (Malfunction Indicator Lamp), commonly known as Check Engine Light illumination. However, there may be noticeable fuel odors in some cases.
Causes
A P0453 DTC trouble code may be caused by one or more of the following:
