I think it's on PAL mode or either way I really dont have any idea about this but the picture is on Black and White.. How will I change the setting thru remote control 'coz I've check on the manual but it's not on the manual.. Thanks
i've tried it already ms witch but where will i find the setting for PAL or NTSC? It's not on the choice or on screen buttons.. if i push the numbers button the tv channel will change.. need more specific instructions please..i've tried it already ms witch but where will i find the setting for PAL or NTSC? It's not on the choice or on screen buttons.. if i push the numbers button the tv channel will change.. need more specific instructions please..
you must have changed the pal version(if you are in pal territory)or ntsc to opposite ones this is a common problem try changing them to the original ones some tvs cannot support the opposite tv territory because of some technical problems so they go into black and white that is what happened
you can see pal or ntsc setings in the settings menu
if this helped you or you think that i spent some time to help you please rate helpful and rate this helped you
satelliteand cable TV is only comes in black and white. this a HTML type plug or a coaxial select menu and source
very weird... should default to colour if no luck try plugging in a desk top digital box tune using that
In order to play a different region game on a different region TV (example playing a PAL game on a NTSC tv) your tv needs to be automatic enabled. Some tv's have an option on the remote to change the input signal to PAL NTSC or SECAM. If your tv does not have that then there is literally nothing you can do apart from get a different tv with this feature.
Check to be sure that the setup is correct. The picture you are describing is what happens when you play PAL into an NTSC unit. I don't think you are in PAL mode.
In black and white? If there is a red and yellow, white and yellow, or red white and yellow on the tv end make sure the colors are matched correctly. Try on channel 3. Try on another tv. Is the camera from a foreign country? (Might be PAL, not NTSC.) If so, there should region menu in the camera to change this. For video, you have to shoot it in the mode of the TV you want to watch it on. North American TV's are NTSC, so shoot with the camera in that mode. If you shoot in PAL mode, a north american TV will show a black and white rolling picture. Just about everywhere else in the world is some version of PAL.
where's the system menu?? i dont see it on my dvd..
