Question about Braun Syncro 7680 Electric Shaver
Braun 7526 electric shaver
Where can i get the shaver cleaning solution in india.
  • 14 Answers
You can make your own solution instead of buying it. The cleaning solution cartridge should list the ingredients on the label (for safety reasons). I have a Braun Pulsonic 790cc and I have been making my own solution for a year. My cleaning cartridge listed the ingredients as: "Alcohol Denat." and "Fragrance." That means "denatured alcohol" and fragrance. Denatured alcohol is simply natural clear alcohol like rubbing alcohol to which a toxic substance has been added to make it undrinkable (e.g.: "denatured").
So just buy some rubbing alcohol at a drugstore and fill up your cartridge with it. If you wish, you can buy a small vial of "lemon essential oil" which is what Braun uses for the fragrance. Lemon essential oil is an aromatherapy product that is used for its scent. I got mine from a bulk food store, but you can also find it on the internet. I bought lemon and orange and I alternate between the two fragrances. Alternatively, you can also use some of your cologne as a fragrance if you want. I also bought a small vial of blue food coloring so that the finished solution is exactly the same as what is sold by Braun.
Here are the quantities I used:
500 ml bottle of Rubbing Alcohol
6 drops of blue food coloring
40 drops of Lemon Essential Oil
Also, before refilling the cartridge the 2nd time it was empty, I thoroughly cleaned the inside. The cartridge will accumulate oils, grime and whiskers from the shaver when you shave, and you can see the debris at the bottom of the cartridge where it gets trapped by a very fine mesh sheet of filter. To clean the cartridge, first fill partially with water, shake it well and drain. It's a good idea to keep the original cartridge cap for cleaning, or if you want to travel with your cleaning station. Repeat the water rinsing operation a few more times. You will note that the inside of the cartridge will have an oily film and some debris still inside. Put 3 or 4 drops of dish washing liquid detergent into the cartridge and fill halfway with water. Put on the cap and shake for a minute then rinse out the cartridge. I repeated the soap rinse 3 times before the cartridge was fully clean.
Once it is cleaned to your satisfaction, rinse with water a few times to make sure there is no more soap in the cartridge, then shake out the contents thoroughly and allow to air dry overnight.
Refill with your home made cleaning solution and you should be good for another 4 months :)
Posted on Jan 23, 2010
    President:
  • 2,961 Answers
If you have Boots in India, get it there
Posted on Aug 23, 2008
2 Suggested Answers
brector3
  • 1612 Answers
SOURCE: Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Nov 28, 2010
Power cord
braun 7030458 syncro shaver charging cord for electric razor braun 7526 adapter power cord replacement parts.
Jun 01, 2013 | Braun Syncro 7526 Electric Shaver
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
My power cord is lost, what is the alternative
Braun Syncro 7526 power cord is Braun 7030458 charger cord replacement.
Jul 15, 2010 | Braun Syncro 7526 Electric Shaver
Braun 7526 trimmer will not move to the up position
The trimmer is extended by the button on the opposite side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 24, 2009 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
317 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
