Projector won't switch on
Hi, i own a optoma h50 projector (NOT A H30 as stated below) that won't switch on,when i touch the standby button the projector just makes a clicking noise can anyone help and tell me what this is please
    Problem Solver:
  • 7 Answers
You may have a failed power supply or a blown lamp. If you have access to a spare lamp, try changing it. (as described in the user guide). If you know the lamp is good for sure, then it is better to call service folks.
Posted on Aug 23, 2008
SOURCE:
Optoma H30 -- When turning on projector the green light on power button blinks and the projector sounds like it is going through a cycle....after the cycle the lamp light comes on and nothing comes on the...
If the lamp light is orange then the lamp ballast circuit or power to it is no good.
I presume the lamp is not on at all, and it's not the hide function that is stopping the light coming out.
Mar 10, 2011 | Optoma H30 Multimedia Projector
Acer projector pd525 will not power off
software related problem, may check for an upgrade on the web.
Feb 24, 2010 | Optoma H30 Multimedia Projector
I have optoma dv10 projector the dvd is playing but there is green flickering lines over the picture can anyone help
Hi
Try to change the cable from source to your projector. or make sure everything is connected properly.
Hope this help
Apr 02, 2009 | Optoma H30 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Optoma projector image yellowing
Very odd problem. Depending on the hours of the projector it could have some glass in it that over heated. Contact Optoma directly, my guess is they will work with you.. good luck
Apr 06, 2008 | Optoma H30 Multimedia Projector
No power
I had to replace the internal fuse after my light bulb burst. You can remove the case by removing the screws on the sides and the carefully slide it off. The fuse is under a plastic cover by the power plug location. I'm not sure if this will fix your problem totally though. I just installed my replacement bulb and I get the solid orange light for 30 seconds and it goes into standby mode again.
Nov 06, 2007 | Optoma H30 Multimedia Projector
Noisy projector
Hi there
It is a pitty that they quoted you so much for the replacement of a colourwheel - because it really is'nt a expensive part to have replaced.
It makes me really mad that some repairers take chances like that with their clients.
Sep 10, 2007 | Optoma H30 Multimedia Projector
93 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
