I have just moved to a new house. I moved my Samsung HCM4216W projection TV to my basement. It was working fine for few days but then I started getting double images, i.e. for every image I see yellow and blue shadow around the actual image. I also see orange color band at the top.
    Genius:
  • 2,920 Answers
You will need to have the convergence reset when u move a big screen it jars things around
Posted on Aug 23, 2008
Tv was working fine but due to a house move on way to new house went over a few speed bumps and now there is no picture samsung
Take the tv back cover out check for loose connections,reconnect all connections tightly and firmly.Check the projection lamp again,might be broken or damage on the move.
Nov 27, 2010 | Samsung HLN5065W 50" Rear Projection...
TV Powers on and then shuts down and attempts to start again
Remove all connections from the tv other than rf cable. This is an hdmi lockup problem sometimes related to component video inputs depending on firmware version.
Jun 21, 2009 | Samsung HCM4216W 42" Rear Projection...
TV has no sound or picture
for this set you have !!
wow do this for me OK
with the set turned off press INPUT and MENUE on the front of set.
now count the flashing led.
it will pause for a secon number count on error code
like one blink then fast two blink this is a error code of 12 meening set is ok but then ther are manny other codes.
i need the code to help you out.
thamks,
daniel.
Jan 11, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
TV turns off by itself (not timer issue)
Probable bad green CRT. Also, look for coolant leak from
CRT onto PCB.......T
Oct 24, 2007 | Samsung HCM4216W 42" Rear Projection...
HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Sep 25, 2007 | Samsung HCM4216W 42" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W Power Problem
Vern,
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps!
Bill
Mar 05, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
