key on> or off? .??????????????????????????
head lites on of off???????????
the lamps are just one switch in the transmission side.
if it sticks on, (bad) it shows reverse when not in reverse, key on.
does it?
My first thought would be a bad ground connection in the harness for the rear lights. You might want to take a test light and check the contacts in one of the sockets.
Did you bleed air on ur BRAKE MASTER?
Brake lights stays, must've the BRAKE switch on your pedal area is STUCK UP!
Either its been damage when ur pumping ur brake during bleeding!
Check that!
Tahh!
You have a brake light switch on your brake pedal. First check to see that the switch is closing when the pedal is off. Then check your light bulbs and fuses for the tail lights.
