Philips Rear Projection Issue with Color Alignment.
I have an issue with 46" Philips Rear Projection HDTV. This TV has a slight problem with the alignment between red and green, creating a small green wave in the lower left corner of the screen and making a large portion of the image slightly blurry. I am wondering what the issue may be and how it can be resolved. The tv is a few years old. My parents said I can have it if I can fix it. I figure its worth a shoot. Thanks for your time and help.
    Master:
  • 848 Answers
This seems to be convergence problem in your tv .............
Posted on Aug 23, 2008
SOURCE:
If a Sony rear projection Tv is showing a red shadow on type is it the bulbs?
This problem is very common with rear projection TV's.
It is related to one or more of the colour guns (Bulbs) being out of alignment. The only way to correct this issue is to have a technician come in and fix it or bring it into a repair center. I personally would suggest purchasing a new TV. The cost of getting them aligned is usually more then a basic LCD.
Hope this helps
Dustin
Jan 12, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I was given a big screen Magnavox TV model #38346033. I don't know how to clean the screen. Also the screen has red, green and blue that needs to converge and I don't know how. I don't have the remote or...
Hello linda, hi, I dont think the remote or manual can help the color issue problem, the tv needs to be looked at by a qualified technician. If the TV is a tube type, there are magnets on the neck that needs alignment, this alignment is done while the TV is ON. so high voltage risk are likely. keep out and call service.
Jun 15, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
KP-46WT500 46 in. Rear Projection HDTV-Ready Television: I'm losing the top and bottom of my picture. The ...
Make sure you try two different sources to the tv, such as a cable box, dvd player and/or gaming system. If you have issues with all sources then it is for sure the tv and there should be a format option. However if it is only one source that the issue is with the issue is of course the source.
May 07, 2010 | Sony KP-46WT500 46" Rear Projection...
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Color on tv are off green red blue as if it was three D. HELP!!!!
Yes, its problem of convergence out chips failure, replace two big black convergence out chips in TV to fix the problem.
If you are handy with electronics stuff repair and can replace parts in circuit board with proper tools then you can fix this TV issue by yourself or ask local tech to repair it.
Thanks.
Jan 15, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Whites are real bright and has an orange color
Hi my name is Eric,
I can help you with your issue ,
 This philips TV could have a number off issues, fluid leaking from a CRT,
or the SSB or SSM boards are bad.
I tech will charge you over $350 to replace a board.
There are color adjusters in the back inside the TV , red blue green screen controls, it wouldn't solve your issue , but lowering on may make it watchable for now
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 07, 2009 | Philips 60PP9202 60" Rear Projection...
My phillips 60 in projection tv has color distortion and the multipoint converge wont let me adjust the cross hairs
Hi..... well if is a LCD Rear projection Tv is a issue with one of the color filters, and you will need to change at least the optical block or the light engine system, I always buy them from www.discount-merchant.com
If TV is DLP it might be a issue with the color wheel, you might be able to hear a buzzing sound.
Jun 27, 2009 | Philips 60PW9363 60" Rear Projection...
Philips 46 Rear Projection convergence off on part of the screen
you may have bumped the alignment rings on the convergence yoke on the red tube while doing the coolant as that could cause the symptom youre describing.
Aug 25, 2008 | Philips 46PP9302 46" Rear Projection...
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Ekse
