Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
My AC 225-S welder is missing the wiring diagram. The cooling fan wires are pulled apart. Need to know if the fan is 110 or 220 and where to put the wires back. Billy Lynch
    President:
  • 643 Answers
Fan Motor MOTOR
2910.0
230.0 AC
Here is a Picture of the wiring Diagram that should be on the inside of the rear cover If this is hard to read Here is a link to the original
Posted on Jun 27, 2011
  • ypop2002 Aug 22, 2013
    My Lincon AC 225 welder fan is 220 volt
SOURCE:
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
How do you wire the old lincoln 225 ac welder
What are you wiring? Power Cord? Fan? Transformer? You should see a white wiring block in the lower right corner if you are looking from the back. On the two top post the black and white wires are attached. The green ground wire is attached to the case. On the two bottom poles the fan lines attach one on each side and the transformer wires that are coming up from the transformer are attached on the same poles as the fan wires.
Apr 27, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
Where does the three power wires hook up to the off on switch. The diagram on my welder is faded. There are two gray wires and one green-yellow wire. I have a Lincoln 225 AC welder
The two gray wires are the Hot wires and the green-yellow is a ground/neutral wire. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Lincoln AC-225 230V
Need the diagram for an old welder, ac/dc 125/225 need to find out how to hook the fan up
Usually the fan if it is, 112/225V. It simply connects across the Line, Phase to neutral, but AFTER the mains switch. So that it is "On" only after the Power has been switched on.
Feb 10, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
Cooling fan/ lincoln 225 arc welder
the fan should be pulling air from the front of unit and out the back.
Jun 10, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
6,087 people viewed this question
Top Lincoln Welding Tools Experts
Greg Bernett
Greg Bernett
Craig Butler
Craig Butler
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
