Question about JVC MX-GT88 CD Shelf System
I have a JVC compact component system MX-J100
The disc drawer or carousel will not open with either the remote control or the actual control on the machine.We hear a whirring noise and a error message appears on the consol please could you advise.
SOURCE:
  • 319 Answers
SOURCE: Error message No Disc
Unit has bad disk t-table motor
Posted on May 07, 2008
  • 224 Answers
SOURCE: my compact component system mx-gc5
This is probably a fault on the power supply sometimes caused by a diode. If you are capable investigate but if not PLEASE dont try anything to put your life in danger as the voltages present in the stereo can easily kill or injure. Good luck.
Posted on Sep 26, 2008
  • 77 Answers
SOURCE: Can't control volume on JVC MX-D402 system
the control knob in shelf stereos from frequent use wear out quickly. contact the manufacture and see if it would be an adventagious avenue to replace the volume control. if not to spendy.
Ryan
Please take time to rate this.
Posted on Feb 19, 2009
SOURCE: Need to set clock on jvc compact component stereo
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Posted on Mar 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: My jvc compact component system
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Can or will u help find the right remote 4 a jvc compact component system # MX-J500
Contact jvc, a jvc service center or one of the many online remote control stores. A Google search would help too.
Oct 20, 2016 | JVC Audio Players & Recorders
My LG dvd player, says loading and eventually disc error, even when there's no disc inside, I dismantled the motor and dvd flexi beld
Oh dear sounds in mess sadly more so with you taking it apart as they are sensitive to static electric which can damage it.
I will try though, I think its too late, first get the remote out of sight of your player (a damaged remote can fire duff signals which bother equipment).
Next check that its machine buttons push and "click" not stuck in/on this can annoy a machine make it react badly.
Now the next is very tricky and I assume you have put it back together!
With it turned off DVD's and CD players have a small hole on their fronts (unless its real old then can be underneath) which a small stiff wire or tool is pushed to get its tray open if a disc gets stuck. A 1mm drill bit may work or similar diameter prod/probe, the idea is to enable you to open and gently pull out its drawer.
With this done and it all its wires back from any dismantle you may have done, power it on.
1) the tray should go back in set its load switches and make the optics take up"start position" moving near to turntable plus lens can be seen moving with red glow (DO NOT LOOK AT LIGHT ABOVE IT only at SIDE).
2) the tray does not or badly moves but a whirring noise is heard, mostly a belt drive tray type and it has stretched needs a change, see also if lens lights and moves as above, IF NOT ditch it.
3)It does not move with no noise maybe with erratic displays no laser or lens action then very bad fault, in short not worth repair, ditch it.
More than this it will require expert help which an average person is not equipped to handle not only in adjustments but many I find need re-lubrication because of grit, debris or grease gone stiff.
Hope it helps.........
Jun 03, 2016 | LG Televison & Video
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
I have five discs in there. The drawer won't open. I can hear whirring noise.
You can try unplugging the unit and waiting a few minutes and then replug and reboot the player. If it still does not work you might want to check the eject mechanism for operation. Maybe a blet slipped off a pulley?
Apr 06, 2015 | Audio Players & Recorders
I am looking for a JVC Compact Component System MX C5 remote. Does anyone have one?
Search online for any of several sources of replacement OEM remotes.
Jan 23, 2015 | JVC Audio Players & Recorders
JVC MX-C5 Compact Component System has a broken mini gear
If you can't get it to work, I would love to purchase the remote as I have lost mine.
Dec 04, 2013 | Harman Kardon JVC UXG50 Micro Stereo...
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
My Aiwa HV-MX100 vcr has not been used in about 18 months. When I insert a tape, I can hear a whirring noise, but the tape will not eject properly. Also, the power will not shut off completely - the...
Is your VCR fixed?
From what you have written, I understand that you have not used the VCR for many months. And since you are hearing a whirring noise, the eject motor is working, but the belts are spoilt, and are slipping. Hence your problem. I suggest you open the top cover of the VCR and observe the eject mechanism. As suggested, you will - in all likelihood, observe that the belt driving the eject gears is slipping.
May 27, 2011 | Aiwa HV-MX100 VHS VCR
I HAVE A 5 DISC CHANGER.......I PLUG IT IN, TURN ON POWER AND THEN PUSH OPEN. OPEN COMES UP ON THE SCREEN BUT THE TRAY DOES NOT OPEN. WILL NOT SKIP FROM ONE DISC TO ANOTHER EITHER???????? ANY...
The 5 disc carousel CD player has a belt driven mechanism in it. And after about 3-4 years the belt looses its tension and cannot push the tray in or out. If you keep your ears on the top cover and turn on the system you will hear a whirring sound coming from the inside which will prove my point.
There are two belts in the machine. One for the eject mechanism and the other for disc change mechanism. One has to seek professional help to replace both because there is timing sequence also involved like the cam shaft of an engine.
Mar 08, 2011 | JVC XL-F154BK 5-Disc CD Changer
JVC MX-GT88 CD Shelf System Logo
71 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
