Question about Pentax Optio S4 Digital Camera
Higher res pics on OPtio S4
How can I take pictures on my optio so that the resolution is set to at least 300dpi... I'm taking high res pics but the dpi resolution on all of them is only set to 72... Any help appreciated!!
    Master:
  • 542 Answers
So far as the camera itself is concerned, dpi is a meaningless statistic. All that matters is the number of pixels. Apart from file size implications, the more the better. dpi only comes into the situation when you display the image. If you display the image on the screen at '100%', or 'full-size', then (somebody told me) this is roughly, or traditionally, at about 72dpi. If you size a 6 megapixel image to A4, then it's at around 250 dpi (I forget the exact figure but you see what I mean). dpi just stands for dots per inch - it's a measure of how closely or not the pixels are packed together in the displayed image. In theory the closer together (higher dpi) the better. People have in their head that 300 dpi is necessary for a good, detailed print. Actually without very close scrutiny most people can't tell the difference above about 230. The bigger the print you do, obviously the lower the dpi becomes. It's complicated by the fact that most printers will 'resample' the image anyway in their own software, so that even if you are printing a picture at a very low dpi figure, the printer will create dots to make up the deficit, although the result will be a softer image. Which is why you don't normally see pixellation on your home printer, even though the dpi figure may be very low ...
Posted on Aug 30, 2005
    Master:
  • 542 Answers
This resolution doesn't matter to most software. It doesn't change the image at all, just occasionally the size it is displayed (only if the software scales the image according to the resolution, which most don't). This having been said, I doubt there is a way to change it in camera. But you could certainly change the XResolution and YResolution meta information with any good EXIF editor. Also, Photoshop can do this too, but it will mess up other things in the meta information. You should be able to script either to apply this change to a number of photos at once.
How to set for 300 dpi
The dpi is not really a camera setting. The camera should usually be set to the highest resolution possible (4000x3000). This capture size would give a print size of approx 13"x10" at 300dpi. That would be considered a high resolution print. If you were printing at "normal" print resolution you could double that print size.
May 20, 2014 | Pentax Optio W80 Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
How to upload picture in computer by using optio digital camera s4
Hello
The following link is a general how to guide explaining how to upload photos from your camera to your computer.
Click HERE to navigate to link.
Kind regards
Andrea
Nov 10, 2010 | Pentax Optio S4 Digital Camera
How do i use my optio m50 as a webcam?
You don't. The Optio was designed as a camera, storing high-resolution images (and videos) to a memory card, not to stream low-resolution video live to another device.
Jun 22, 2010 | Pentax Optio 50 Digital Camera
Pentax Optio S4 Keeps on saying "memory card error" I've tried 2 other memory cards but with same result. What should I do? Kay Ara
You need to format the card in the camera to get it to work. This will erase it so download any pics from it first.
Mar 11, 2010 | Pentax Optio S4 Digital Camera
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
Apr 17, 2008 | Pentax Optio S Digital Camera
Optio s4 - help needed
You are probably in play mode and not in camera mode. Switch the camera back to camera mode (move the witch so its in the camera position- you will see a small camera icon) in order to take pictures.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
S4 LCd problem
my screen wont let me do anything the screen comes up as card locked
Pentax Optio S4 Digital Camera Logo
150 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
