Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opener not working properly
My door goes down part of the way and then goes back up.
  • 34 Answers
Garage doors have safety sensors so the door does not hit the car or anything else that gets in the path of the door. Check to see if anything is blocking sensor mounted on the track near floor. Also sensor my have been bumped and not in alignment. Hope this helps
Posted on Aug 24, 2008
3 Suggested Answers
  • 3197 Answers
SOURCE: Garage door started not working properly.
Check your door sensors.
Posted on Feb 17, 2011
  • 3197 Answers
SOURCE: Garage Door Opener Closes properly but then goes
Check sensors in doorway.
Posted on Nov 07, 2011
My garage door goes up a little and down doesn't open all the way up
look where the motor is on the ceiling rafters there is a cord rope hanging down / pull the cord down to release the lock trigger / close the door / push the open button the motor will run the chain back then forward till it locks / door should open and close properly after this
Mar 04, 2018 | Building Materials
The garage door goes down to about 10 inches off the floor, then re-opens and i get a flashing light which goes off 10 times
I think your garage door safety device has been bumped and is now out of proper alighment. Has it worked properly in the past? Check the alignment of the two boxes (one on either side of the door) to assure they see each other and not the door as it comes down.
The idea of the device is if the light wave is broken, (something goes through the door as it decends) the door reverses and goes back up.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Kitchen Ranges
My garage door starts going down and stops. it goes back up and will not close. one of the sensors is yellow.
take some toilet paper, or some very light rag and dust the RPM sensor over, under, inbetween and in every spot on that darn thing, and bingo, it will work. Its the plastic ribed piece mounted on the end of the motor under opener cover. If something gets under door as door starts to go down, the RPM`s will slow and thats a warning to stop and go back up. With it being dusty, it can`t sense the RPM`s properly and goes into an alarm every single time. Ugg
Mar 10, 2011 | Chamberlain Powerdrive PD422D 1/2 HP...
We just replaced a broken spring (re[laced both sides) on craftsman garage door opener and now the door won't shut all the way. It goes down to about 12" from closing and then goes back up.
YOU COULD HAVE THE WRONG SPRING OR NOT ADJUSTED PROPERLY. YOU COULD HAVE AN OPERATOR ADJUSTMENT PROBLEM.
HOW DOES THE DOOR WORK MANUALLY??
IF IT IS HARD TO PUSH DOWN AT THE BOTTOM - SPRING PROBLEM - IF IT WORKS AND CLOSES VERY SMOOTHLU AND EASILY THEN YOU COULD ADJUST THE DOWN SENSITIVITY - JUST A LITTLE.
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door goes down 3/4 way down then goes back up and flashes 10 times
Your door sensors have probably been bumped and are misaligned. They must be pointing at one another to work properly. Each of them has a small light that should be lit. If you cannot get both lights on the sensor to come on you probably have a sensor that has quit working.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not go down
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a door sensor problem. Check to make sure one of the sensors is not blinking ever so slightly. It can be hard to see. Also make sure direct sunlight is not hitting the lens. Try shading them.
Jul 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener won't close completely
look on the side of the openeer usually lekt looking at it from the rear theese are your travel adjusters one turn = 2" travel normally
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
48 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
