Question about Brother DCP 130C All-In-One InkJet Printer
Unable to clean 46
Help, i have rad your solution on how to solve a brother printer that has numeric keypad, but the problem is,,, my brther dcp 130c dont have numeric keypad so i cant enter the digit.. is there anyway to reset the purge counter coz theres an error showing unable to clean 46.. anu help would be appreciated.. thanks
Posted fix in another prob same section
Posted on Aug 31, 2008
Unable clean 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Feb 02, 2011 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46 dispaly
Try to reset DCP printers without numeric keypad.
Follow this:
Jan 14, 2011 | Brother DCP 130C All-In-One InkJet Printer
My brother printer DCP135C have to following error message how to clear it "clean unable 46 see troubleshooting and routine maintenance chapter to user's guide"
Follow this:
Don't forget to vote Thanks!!!
Oct 29, 2010 | Brother DCP 130C All-In-One InkJet Printer
Clean uneable 46 brother dcp 130c printer
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All the best Pineworks
Apr 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
How to solve the clean unable 46error of a BRother dcp-130c printer.
Clean unable 46 means you need a new flushing box. It's where the ink goes when it cleans the printhead, and yours is full. You need a shop to replace it.
Jul 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Dcp130c UNABLE TO CLEAN 46
press the menu and mono start keys next pess the arrow up key 4 times to make machine enter matinence mode
2 enter 8 and 0 by using arrow key and set key
3 press mono start key several times until the purge count appears on the lcd
4 ente 2 7 8 3 by using arrow key and set key to reset the purge counter to zero
5 press stop/exit key and return to the intial stage of mantince mode
6 enter 9 twicw by using the up arrows and set keys to exit from matince mode
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
have cleaned tanks , need to reset counter? any help as to how?
Jun 22, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
IT means you  need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Jan 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
421 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
