Question about HP LaserJet 3050 All-In-One Printer
HP 3050 All in One
I need help Replacing he Modem in the Hp 3050 All In One
  • 75 Answers
With the rear of the printer facing you.remove the right side cover(one screw at rear)then remove modem by removing screw which holds the little board ,this is the modem(has two telephone connectors on it) install new modem
Posted on May 10, 2010
I bought an HP 3050 J610 printer less than a year ago, and need to replace the ink cartridges. Elsewhere on this site Upvarish advised someone else to use 61 cartridges, when the person asking for he
The HP 3050 Deskjet All-in-One takes the HP 61 cartridges: http://www.shopping.hp.com/product/CH376A%2523B1H . There are 2 cartridge boxes (black and tricolor: cyan, magenta and yellow). Both regular or extended use cartridges are available.
I hope this helps. If you actually have a Laserjet printer, please give the model of the printer to get the toner cartridge you need.
Feb 18, 2012 | HP LaserJet 3050 All-In-One Printer
How to replace adf scanner unit in printer hp lj 3050
The Adf of this model isn't replaceable. Hp clearly mentioned on several threads. Open this [click here] and read the "Note:.." written blue texts. If you wish to refer to the service manual, Click Here, but replacing the ADF isn't included for this model.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 11, 2011 | HP LaserJet 3050 All-In-One Printer
My brother just gave me a HP LaserJet 3050 and for some reason i can't send or recieve faxes. What would be my problems?
First plug in the phone line into a working phone to see the the line works. If the line works you may need a new modem for the 3050.
Jan 07, 2010 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Low memory on HP Laserjet 3050
low memory error on my hp laserjet 3050
can anyone help
Dec 31, 2007 | Nikon COOLPRINT Thermal Printer
HP LaserJet 3050 All-In-One Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
