Question about Pentax Optio S5i Digital Camera
Menu, controller and display button locked
I gave my camera to a friend for a few days. Now that I have it back I can take photos, but the menu, 4 way controller and the display button are all locked. When I try to use these options an orange padlock appears on my screen, has anyone else had this problem? Would anyone know how I can clear this so that I can use the menu and other features. I have been through the manual and can't seem to find anything regarding this problem. What would my friend have done to create this problem? Any help would be much appreciated.
It means that the camera is in 'Green' mode. Turn off the green mode by pressing the 'Green' button (also used as the delete button when in playback mode).
Posted on Jun 15, 2007
    Master:
  • 542 Answers
Could be your friend has turned on the SD memory card lock. From page 136 of the camera manual: The SD Memory Card is write-protected. Only menu operation and mode change are possible.
Posted on Aug 30, 2005
MY FRIEND JUST GAVE ME HER OLD PHONE WHICH IS A MOTOROLA MB300. BUT THE PHONE HAS A PATTERN LOCK BUT SHE FORGOT WHAT IT IS. CAN SOMEONE HELP ME?
Welcome to Fixya. If the you don't know the lock code you can try the steps below so that you can reset the phone to it's factory state.
1. Power off phone. 2. Hold camera button and power on phone at the same time. 3. Release the camera button when prompted to. 4. You will see a message screen telling you to press the up or down volume button 5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed') 6. When triangle and phone screen appears 7. Press on the screen just above the back key 8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back] 2. apply ssdcrad:update.zip [Alt+S] 3. wipedata/factory reset [Alt+W]
Select the third option to do a factory reset.
Thanks You can simply tap an item to select it.
Aug 02, 2011 | Cell Phones
Controls don't function
Can you set the time and date. Some require the time and date be set before proceeding.
Jun 21, 2008 | Konica Minolta DiMAGE G500 Digital Camera
How can I erase my sd card? I thought it was empty, but when I went to print from my disk only, it said I have like 1600+ photos on it! I should have only had 152, according to what I thought I'd erased....
First of all make sure the write protect lock is off on the left hand side of the memory card, the slide lock should be in the up position.
Press the MENU/OK button on the camera to display the menu. Use < or > buttons to select ERASE. Then use the up/down buttons to select FORMAT, then press the MENU/OK button.
Press the BACK button to exit the menu.
Please be aware that all data is erased from the card so make sure to back up any file you might want.
Regards.
Sep 29, 2009 | Fuji FinePix S8100fd Digital Camera
Friend gave me his old Samsung SGH D500 but had lost instructions
button on back of phone near top, press in and remove battery, you should see a sim slot? slide your sim card in, re the camera, go to menu/camera/ok/ok/ok, you have just taken a photo!
Apr 29, 2009 | Samsung SGH-D500 Cellular Phone
Viewing photos without time and date
Unfortunately the Nikon Coolpix 7900 does not have a 'display' button to take care of this. So you need to go through Menu to access Setup menu. Here you will get option to customize the display.
Feb 09, 2009 | Nikon Coolpix 7900 Digital Camera
Olympus e510 shutter button locking up
reset the camera through the menu.... put the camera in P mode, menu, right over to card setup, down to custom reset, right arrow, ok, up arrow to yes, ok
Oct 14, 2008 | Olympus EVOLT E-500 Digital Camera
Shutter release/AE lock and control panel display
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
May 27, 2008 | Nikon Coolpix 8700 Digital Camera
I can't delete locked or protected photos from my camera
More to the point, you can download a PDF copy of the manual here. Just input the model number and hit continue. While there, you may also want to check for firmware updates. As for locked/protected files, check and see if the write protect tab on your memory stick has been engaged.
Here's the deletion procedure:
  • Turn on the camera.
  • Press the MENU button.
  • Press the right arrow on the control button until the Setup menu is displayed.
  • Press the down arrow to select the icon for Internal Memory Tool or Memory Stick Tool.
  • Press the right arrow button.
  • Press to down arrow button to select Format.
  • Press the up arrow button to select OK.
  • Press the center of the control button.
  • Press the up arrow to select OK.
  • JD
    Digital Camera HQ
    Dec 26, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
    Does the L410 do audio recording?
    Videos with sound is possible or you can record sound memos as well
    Recording and Playing Sound Memos
    You can record and play back sound memos for your photos while you view them on the LCD screen.
    1. Turn the Mode dial to playback mode.
    2. Press the MENU button. Playback Menu 1 is displayed.
    3. Select Sound Memo by using the u d buttons, then press the r button.
    4. Press the OK button and then start recording.
    5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
    a new memo.
    6. Press the MENU button twice to exit the menu.
    When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
    button to play the sound.
    Note:
    You must have at least one photo saved to record a sound memo.
    Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
    Pentax Optio S5i Digital Camera Logo
    369 people viewed this question
    Top Pentax Cameras Experts
    Geoff Hone
    Jerry Greenberg
    Jerry Greenberg
    Mohamed Ismail
    Mohamed Ismail
    Are you a Pentax Camera Expert? Answer questions, earn points and help others
