Question about LG Televison & Video
Looking for an lg part of the asus pcb module 2300kcf005b-f
    Master:
  • 505 Answers
Try tv repair place cant find any online sorry
Posted on Aug 23, 2008
The SE light flashes when turning on the washing machine
Not sure which washing machine you have. But assuming it is an LG SE is a serious fault.
Motor fault detected Can also be caused by be main PCB
This is not a good fault code to see as it will generally be correct and either the washing machine drive motor or the main electronic control PCB is faulty.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
For more detailed analysis please post make and model of your washing machine in the comments field.
Sep 26, 2014 | Washing Machines
What does a pcb look like i want to make sure i am right
PCB means printed circuit board.All the boards in your TV are PCBs, Please specify which board. example YSus, ZSus, Power Supply. Control board, YDrivers etc
May 17, 2014 | LG 42PC3D 42 in. Plasma Television
Lg tv initialization on screen and not going on
most likely power PCB,( look for those leaky capacitors) could be the mpu , but still requires the power PCB.( check your voltages on the PCB.) Could also be the I/O PCB.
May 08, 2014 | Televison & Video
Door lock error
Unplug the unit and plug it back in. This usually fixes it.
However if not, someone will need to inspect the oven door lock module to determine if the PCB or the module is at fault.
This model is a little difficult to diagnose without see it.
Apr 05, 2013 | LG LRE30451 Electric Kitchen Range
My 42' LG plasma tv model number 42PC1DA-DU monitor is not show but the sound is working. What should I do?
In this case, the defect is in Y-SUS PCB, change it and adjust the voltage that are specified
on sticker attached to plasma module
Feb 25, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Black screen with power switch flashing blue.
I have been same problem but in other type syncMaster, the solution is open your LCD monitor look for power supply module (PCB which have connector to AC power), on that PCB look for capacitor , for normal condition its look like small tube. now look for broken one which upper part is bloated.
Nov 23, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
I have an LG 42 PC 5D it just shut off on me last night and won't turn on today. The green on button comes on then the red comes on right after it. what could be the problem.
Most likely the Y-Sustain PCB.
6871QYH051P if it's a 42X2 PDP Module
6871QYH053B if it's a 42X3 PDP Module
It depends on when it was made as to which is fitted.
I'd bet the fuse(s) are blown on it, signifying it has failed.
They are about £200 New from Charles Hyde. www.chsinteractive.co.uk
Sep 03, 2009 | LG Televison & Video
Lg WM12225 wasahing machine.Error code LE shows.The drum does not turn but stutters.Is it 1.A faulty module 2.Faulty rotor sensor 3.Faulty stator
LE is an error code for the stator. Rare occasions it is the PCB as well. The stator sensor is only there for the PCB to know what direction the rotor is turning.
Dec 03, 2008 | Washing Machines
TV turns OFF and ON
No it is not. There is no fransfer of memory for the power module, but there is for the control module (main pcb). RCA also has a problem with 2 connectors that go bad. One on the power pcb and the other on the convergence output pcb. They are white in color. The good ones are black in color. Look for the 2 ribbon cables that connect from the main pcb to the power pcb and see what color the connectors are.
Apr 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Computer Repairing
Computer Repairing
