Question about Dell Inspiron E1505 Notebook
Battery not charging
I have a pup that chewed the charging cord. I repaired it and am getting the
correct voltage out of the cord connector. I am getting on the lower right tray "connected but not charging" Is there a circuit that controls the charging of the battery? What would you suggest?
Carl
  • 3,940 Answers
There is a "sensing" circuit that tells the system the wattage of the AC adapter. If that connection is damaged, the battery charger will not operate.
Most likely, you'll need new, 90 watt, ac adapter.
You shoujld be able to get a replacement for under $30
http://shop.ebay.com/items/_W0QQ_fromZR46?_nkw=inspiron+6400+ac+adapter&_fromfsb=0&_trksid=m270.l1313
Posted on Aug 23, 2008
Dog chewed off cord on my masterbuilt electric smoker model 20072010. How do I replace cord
This cord connects to the smokers elements and contains mains voltage witch can kill you if contact is made with a bare wire. Get a tradie to make the repair play safe.
Dec 24, 2014 | Grilling
My pups chewed the Therastat wire connecting to the AC, Now the fan in the inside comes on fine but the out side blower wont come on at all Help. Sincerely live in Victorville the hottest place in the...
First correct your wiring its possible it could have damaged your thermostat either way your wiring needs to be repaired then take it from there
Aug 15, 2011 | Heating & Cooling
Repaired cord is not working
make sure the plug is wired correctly .. the colors of wires depend on what country it came from .. in the US it would have a black, white and green wire ... the black wire would be connnected to the small flat prong (thats the AC hot wire) .. the white wire would be connected to the wide flat prong (thats AC return) and the green wire would go to the round grouund connection .. if these are not wired correctly then it may not work and could be dangerous .. have it checked by anyone that is familiar with electronics .. make sure the pup didnt chew another spot on the wire ... ..
Jul 02, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
My Computer Wont Charge!!
if the charger power up your laptop,that means that the charger is working fine,what you need to do is just replaced the battery
Jun 28, 2010 | Lenovo IdeaPad Y510 Notebook
Phone will not charge
The phone base uses the terminals in the charger to tell you that it is "charging". It does not sense power.
One of the following is probably true:
1. Cord is not good (check for voltage at charger terminals
2. Connector terminals are compressed from improper connectin - inspect and correct with straight pin (pull all the terminal elements to an equal level
3. Diode in the phone has popped and the battery chargering circuit cannot feed the battery correctly.
4. Battery is bad (shorted, dead).
Best to borrow someone elses and see if it will charge on your charger.
Nov 26, 2009 | Sony Ericsson w580i Cellular Phone
Battery power died and the power cord will not charge or trun on the computer
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
The adapter is faulty or the connector is not making proper electrical contact. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 07, 2009 | HP Compaq nx7400 Notebook
Acer laptop 5570z plugges in but not charging
Check the adapter with a multi-meter, the voltage on the plug that connects into the laptop should have a voltage slightly higher than the voltage that is printed on the lable on the adapter. If you get nothing then the adapter is faulty and needs to be replaced. That is why the battery is not charging.
Apr 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
AC Adapters in laptops
It is not a special chip that dictates if a charger can charge a certain laptop, but these two factors:
1) You need to have a power adapter/charger with the correct voltage and amps. Some common Dell laptops use 19.5V (volts) and 4.62A (amps). I have seen some Dell adapters with 3.34A (amps) as well. If you use an adapter with the wrong voltage and amperage, you could cause damage to the laptop's power supply and/or motherboard...or it just won't work at all.
2) The type of connector to the laptop. Different manufacturer's use physically different connector sizes and shapes. Some are larger and circular with a pin in the middle, while some are smaller with no pin. It depends on the laptop.
You can look at the voltage of the original charger on the brick part (the middle of the cord that looks like a brick). Make sure you get one that matches exactly.
Mar 19, 2009 | Dell Inspiron E1505 Notebook
Computer power
The power connector on the motherboard is not making contact.
This is not a simple procedure to correct due to the laptop needing to be completely disassembled to get access to the motherboard.
If you gently move the power cord around in a circle while pushing towards the laptop it should get power to it until it moves out of place again. Do this while watching the lights panel for any signs of light. Also remember it will take a second or so for the battery charge light to show power entering the laptop, so move the cord very slowly.
The suggested soloution will invole the laptop being sent to your local laptop repair centre for this to be corrected, or if you still have warranty, then get it done by Toshiba.
It is also a common fault to all laptops.. There is just not enough strength in the solder that holds the power connector in place to take years of connecting/disconnecting of the cable.
May 15, 2008 | Toshiba Satellite A135-S4427 Notebook
Durabrand portable dvd player
Try a standard multi voltage charger. These come with a selection of connectors each one of a specific size and color coded. so you pick the connector to fit the input jack then set the charger to the appropriate color to give the correct voltage.
May 22, 2007 | Durabrand 8.5'' Portable DVD Player
Dell Inspiron E1505 Notebook Logo
102 people viewed this question
Alun Cox
