Question about Kenmore Oasis HE 27082 Top Load Washer
Clean Cycle My kenmore oasis keeps switching over to the clean cycle. We have run the clean cycle twice but it still will not allow me to run any other cycle which means I can't wash clothes. Any suggestions???
I had the same problem. After unplugging and plugged it in several times, I got it to switch to a wash cycle. But now it beeps every 20 seconds.
Posted on Aug 27, 2008
Have kenmore oasis washer - beeps when not running or on...when i try to run a load, it defaults to "clean washer" setting - thinking, ok...it needs to be cleaned...i run the clean washer...
F02 means that there is a problem with your user interface control board. A button could be stuck on the board. Try pushing all the buttons to make sure that none is stuck. Most likely u will need to replace your user interface.
Jul 15, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore dryer DW4305295 - dry cycle will not stop,
When it completes a cycle, does it continue into the next cycle? The power switch might be bad if it does. You can take the switch apart and clean or repair it, or you can simply replace it. (They're not very expensive.)
Jun 12, 2010 | Kenmore 63942 Dryer
Kenmore elite oasis washing mchn has a bad odor and cloths smell
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis washer model 110.2709 - Clean washer light is on and machine beeps, after we run the clean washer cycle the light and beep does not clear out. I can't get the washer to run a wash cycle...
Ok this is easy there was a defect on all of them don't worry easy and free fix I want you to call this # (800) 659-7026 they will get your info and send someone out to replace control board. Free. In mean time I want you to unplug washer because it's dc motor it still has juice so hit power then stop tell the lights don't come on plug back in and enjoy the temp fix tell they come out to fix it. Don't worry I sell them and I have one and it is still a great washer it was just the first one out of it's kind so it had flaws but sears is taking care of it's customers.
Apr 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Jan 21, 2010 | Kenmore 67082 Electric Dryer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
98 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
