Sony mhc-rg22 reet everytim i press power on on sterio it comes on den comes up with push power protect it was workin before den it just went of i could smell like burning so i fink i must of fried something but dont know what can u help.iv had a look for fuse's can't see any.
    Genius:
  • 1,550 Answers
Your audio amplifier IC´s of your device are damaged
Posted on Aug 23, 2008
  • barryphil202 Feb 17, 2011
    I have experienced the same problem. I replaced the audio amplifier IC but the fault remains. R395 (680R 2W) was charged but still functioning- I replaced it anyway. I have been unable to source a service manual from anywhere. Do you have any other suggestions?
SOURCE:
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Sony mhc-dx5 power protect
something inside the unit has become faulty electronically, otherwise if u have moved the unit with cds inside, they may be out of allignment and causing the unit to go into protect.
Jul 06, 2009 | Sony Audio Players & Recorders
When i press power on it says push power to protect.When i press power it says standby and then powers off.
the unit has put its self into preotect mode for a reason.
you can trr unplugging the dvd plyer from the wall, that should reset it
May 03, 2009 | Sony MHC-ZX70DVD System
Protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Dec 19, 2008 | Sony MHC-RG30T Shelf System
698 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
