Question about Mitsubishi WT-42311 42" Rear Projection Television
Convergence The vertical lines on my 42" tv won't line up. I've tried the red & blue line up- Also the grid line-up. It will let me adjust the vertical lines, but not the horizontal line. I get red, yellow and green seperated on the icon for the tv station and almost a 3d blurred screen. My tv was moved and droped about 3".
  • TexasTuff79 Oct 24, 2008
    I own a Mitsubishi WT-42311 42in rear projection tv and one day I turned it on and the blue convergence was way off. I tried to adjust and it won't line up. I tried the advance convergence and same deal. Red convergence is fine. The picture is horrible. Sound and all other functions are great. What is wrong and HOW DO I FIX IT?! Repair man said $350. I got a great deal on this tv from a friend of mine a year ago and no way am I paying 350. I'd rather throw it away! HELP!
  • chrisbristow May 11, 2010
    I had the exact same problem, my tv wasn't dropped but I did smell a slight hint of something burning the first time this problem surfaced. We did replace both convergence IC's and the it didn't correct the problem.
    Any suggestions what the next step might be? Thanks in advance for your help.
  • Mitsubishi Master
  • 8,617 Answers
You need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Aug 23, 2008
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi Rear Projection WS
5ebe434.jpg A projection television and a convergence control method thereof are provided. The projection television, which magnifies images displayed on cathode ray tubes (CRTs) for the colors red, green, and blue using lenses and projects the magnified images onto a screen, includes a convergence control apparatus capable of adjusting the convergence while an input image signal is displayed, the convergence control apparatus including: an image signal decoder which processes the input image signal to generate a data signal, horizontal and vertical synchronous signals, and a start signal indicating the start of either the horizontal or vertical synchronous signal; a convergence control unit which normally projects an image signal output from the image signal decoder onto the screen and performs convergence control using a predetermined region of the screen displaced from a visible region of the screen according to a convergence control command; and a main microcomputer which inputs the convergence control command to the convergence control unit when the start signal is input from the image signal decoder, stops the convergence control when a completion signal is input from the convergence control unit, and performs a control operation to continuously display the image signal during the convergence control.
the pro in convergence control circuit only..so better change tat..
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
The screen is distorted ... double words and double picture
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synchronous.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck in solving the problem....
May 27, 2011 | LG 50PG20 50 in. Plasma HDTV
Picture is saturated in green with vertical wavy white lines"
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 15, 2010 | Samsung HCM4216W 42" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Convergence adjusting
you need to replace the 2 stk-110's mounted to the heat sink
i had the same problem
and works pretty good now
Dec 26, 2007 | Toshiba 42H81 42" Rear Projection...
Convergence problem
I have a hdtv my red and blue are offset i need to know how to adjust properly
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
