Question about Philips Magnavox MWR10D6 DVD Recorder
DVD+RW playback problem(s)
My recorded programs seem to be fine until about the one hour mark. Then the picture starts freezing and or skipping (mostly freezing). Also when I first load the disk I'm hearing a grinding(that's as close as I can come to an accurate description)sound.
The time is shown to be (EP) 4hrs It used to say (SLP)2:31
A couple weeks ago I tried recording 2 shows 2hr and 1hr. The second show stopped recording after about 10min
That's the genesis of my current problem. Thank you for your consideration.
  • redketchup Oct 10, 2008
    I feel so stupid. I just found the rec mode today. I had disconnected my dvd recorder and connected a vcr. Then today I reconnected the dvd recorder. So far it works in SPP mode.
    Thanks for the advice :)
You need to change your recording speed back to 6hr....i think it is slp that will record 6 hrs on a disk
Posted on Sep 04, 2008
  • Eddie Shelby Sep 04, 2008
    change your speed back to slp and it should hold up to 6 hrs then
  • 37 Answers
Same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Posted on Aug 24, 2008
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
May 24, 2014 | Televison & Video
Which DVDs do I need to use with the Toshiba DVR19DTKB2 I have DVD+R Will these record from VHS
Compatibility Recording - DVD-R, DVD-RW, DVD+R, DVD=RW, VHS
Compatibility Playback - CD-Audio, CD-DA, CD-R, CD-RW, SVCD, Video CD, DivX version 6, DVD-R, DVD-RAM, DVD-RW, DVD Video, DVD+R, DVD+RW, JPEG Viewer, MP3, NTSC Playback (VHS), USB 2.0
Mar 07, 2011 | Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
During playback picture freezes
it's having trouble reading the disk. clean it. use a disc cleaner from walmart or radio shack to clean off the optical lens, too..
Dec 14, 2009 | Televison & Video
Humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
Nov 25, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Sony RDR-GX355
There can be faults in writer which causes data loss during the recording....the disc is also very important....Try reducing your writing Speed ( For CD-20x , DVD-8x need not to be the same)...
May 10, 2008 | Televison & Video
Recording from DVD recorder to disc
Christine,
1) Put a compatible DVD in the tray. (I have noticed that I must format DVD+R discs, but others are formatted okay for recording -- such as DVD-R and DVD RW)
2) Close the tray.
3) Make sure the player is set to HDD and not to DVD. It will indicate HDD, DVD, or SD on the LCD screen.
4) Using the remote press the "functions" button.
5) Select "copy" from the menu when it appears.
6) You will now see the list of programs you have recorded to the HDD. Highlight the one you want to copy and press "Enter" on the remote.
7) I think there are two confirmation screens that come up, press start or continue or whatever it says.
8) My recorder generally takes about 14 minutes at high speed to copy a two-hour program. If the program is longer than 2- hours, you must divide it into tow or more shorter segments for more than one DVD.
9) If you want to select several shorter programs (not to exceed 2-hours combined) highlight the programs individually pressing the PAUSE button on the remote. This places a check mark next to each of the programs. When you finish, press the enter button on the remote and go through the confirmations screens again.
10) If the DVD is nor rewritable, it will automatically run the "finalize" program. It takes about 3 minutes and runs after recording. This formats the DVD so that it can be played in non-Panasonic players. If it is a DVD-RW, they you must finalize it manually if you want to watch it on other types of players.
Hope this helps,
Nancy
Mar 27, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Camcorder "Freezes Up" during playback and/or during creation of thumbnails
I had the same problem - you are (as I was) turning off the camera too soon after you hit the stop button after recording a scene. Wait until the word "disc access" appears (about 5 seconds after you hit the stop button. This "marks" the end of the scene. I just don't know how to edit that scene out or if it will delete it out. I know after finalizing the disc that scene will pause for a while (10 to 20 seconds even) when you watch it through the DVD player to the TV.
May 22, 2007 | Hitachi DZ-MV730A DVD Camcorder
Windows Media center recorded TV playback
Some possible causes can be system heat causing the video card to freeze. Sometimes it can also be related to the video driver or MPEG2 decoder. Make sure to use the right decoder and filter for the video playback.
Mar 06, 2006 | Microsoft Windows Media Center Edition...
Philips Magnavox MWR10D6 DVD Recorder Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
