Question about Samsung SP1213C 80 GB Hard Drive
THECHNICAL SUPPORT BLUE SCREEN APPEAR WITH STOP 0*0000007B WHEN INSTALLING WINDOW XP TO MY NEW SATA SAMSUNG HARD DRIVE OF 80 GB WHAT WILL BE THE PROBLEM
    Master:
  • 505 Answers
Its a Windows Error Mostly from the software not the hard drive
Posted on Aug 23, 2008
SOURCE:
Install 2nd Hard Drive with different connectors and different OS.
yes you can use either sata power or molex(4 pin) plug to power your new SATA hard drive but not both at the same time.
Mar 19, 2012 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My system window xp is currepted i want install new window xp but problam is this when i am install xp setup is stop before the formeting. plz tell me salutions.
I think you need to do a format of your HD before setup.
Installation on top of another XP is always troublesome.
Obvioulsy you need to be aware you will lose all files !
Aug 14, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Got a 250gigs copied old 80 gig
try re-installing your O/S then delete the partion/s and create a new one it should give you the total capacity after that, post back if you still have questions
Jun 08, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Vista installation
try updating the os using windows update
Sep 20, 2008 | Computers & Internet
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Open Questions:
AOL MAil HeLpliNe {1^/855~/536~/5666-} PHoNe NuMbER OREGON This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 19, 2019 | AOL Computers & Internet
AOL MAil HeLpliNe %%%{1=855=536=5666}#[email protected]@# NuMbER ALASKA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
See all Samsung SP1213C 80 GB Hard Drive Questions
Samsung SP1213C 80 GB Hard Drive Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
