My pc M/s XP on startup is always in safe mode - I've tried msconf, etc but still cannot get any form of screensaver using control panel Display icon - any ideas
  • Steve Rand
    Steve Rand May 11, 2010
    What?
    A screensaver is a pretty random graphics thing for making sure your screen doesn't get burn-in while you're not using your computer for 5 months straight.
    It's more likely that you can't set your screen resolution higher than 640x480 because of some video card driver problem... and you are NOT actually in safe mode. If you were in safe mode, it would say all sorts of stuff about being in safe mode when XP loads.
Hi
Restored Control Panel Display Desktop pic and Screensaver tabs by changing Registry items - Nodisplay background and Nodisplay screensavr to original setting (0) before virus / adware infiltration
regards Alex
Posted on Aug 24, 2008
SOURCE:
Screensaver set
Hi, go to start- Control panel- personalization. Click here and check if the
screen saver is turned off. It is located on the lower right corner. Click on it
to turn the screen saver back on. This is for windows 7.
If you are running XP go to Start- Control panel- Display. Click on the
display icon and there is a tab that says screen saver. Click here and chose
your screen saver.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Oct 19, 2013 | Acer Aspire One PC Notebook
How do i release the user password i could not login
you load xp or windows 7 please reply if u load OS xp then you use CMD software ...
Jul 29, 2012 | Dell Inspiron One 19 All-in-One Desktop PC...
I have a Toshiba Satillite m55-S3315 with XP Operating system and do not remember the Windows Password. Is there a way to bypass this or fix it so I can use my Laptop?
Reboot your machine. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+5009222491+3607312525+8962074949+1162261192+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); 2
  • Press F8 before the Windows boot screen appears. Do not press F5 as used on the NT/9x series of Windows. You will be be prompted with a boot options menu.
  • 3Select the Start Windows in Safe Mode option.
  • 4Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
    • Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
  • 5Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
  • 6The Safe Mode Welcome screen might display some of the other users on your system.
  • 7Login as the admin.
  • 8Press Yes at the prompt asking if you would like to continue using Safe Mode.
  • 9Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
  • 10Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
  • 11Login as the user for which you set the password.
  • 12If it doesn't work above, you can try to use professional support recommendation OPHCrack (freeware) to crack your windows password without erasing anything
  • Mar 13, 2010 | Computers & Internet
    I cannot get to Display to return white so I can make changes
    You need to disable themes. This can be done by booting up in safe mode (pressing F8 on boot and selecting safe mode) Then while in safe mode go to start(then)control panel(then)administrative tools(then)services and then find "themes" right click it and select properties then you will see an option that says "startup type" click it and select disabled. It should remove all themes the next time you boot up normally
    Sep 22, 2009 | Microsoft Windows XP Home Edition
    Error: Cannot Display This Video Mode
    You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
    1. To get into safe mode, continuously press F8 while the computer is booting up.
    2. Eventually you will get a Windows XP Boot Menu.
    3. Choose the option for Safe Mode.
    4. Go to Start, Control Panel and double-click Display.
    5. On the Settings tab, drag the slider bar to 1024x768.
    6. Click OK
    7. Shut down and reboot.
    If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
    Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
    HP Pavilion a420n
    You almost certainly have a virus. If you can't even get into safe mode the easiest way to fix it is remove the hard drive and back up any files on it with a different computer, then re-install Windows on the original drive.
    You can try booting from your Windows XP installation disk and using the recovery console there to repair your installation. That's not too hard and I would say works 30% of the time.
    Jan 01, 2009 | HP Pavilion a420n PC Desktop
    Clarification
    try switching to only "SAFE MODE"
    OR
    you may also try pressing alt+del+ctrl keys at once this should bring up the task manager. you may try to end some process which may be malfunctioning and this will help you to go to the desktop.
    please rate the solution
    My Control Panel crashes when I switch views.
    Please try to open control panel in safe mode and let me know what happens?
    you can go to safe mode by tapping f8 when computer is starting up.
    If safe mode works fine then any of the the start up item, third party service,spyware or useraccount is causing the problem.
    To find if startup item is causing the problem we need to use the msconfig command on run and click on startup item and disable all apply close click and restart on prompt and try to open control panel on normal mode.
    please let me know the safe mode status.
    Aug 19, 2008 | Microsoft Windows XP Home Edition
    Startup
    Possibly 2 reasons:
    1. Driver/hardware/software/application problem; or
    2. Virus/malware.
    You can consider:
    1.1 Run in last known good configuration that worked (by pressing F8 to display menu choices prior to Windows boot);
    1.2 In safe mode, Start/Run/type "msconfig" minus the quotes, uncheck everything in the Startup tab, reboot;
    1.3 In Safe Mode, run your antivirus or run Kaspersky online virus scanner or anything similar;
    1.4 Download/install/run AdAware or anything similar;
    1.5 Check you Control Panel for devices with yellow or red markings;
    1.6 Set your BIOS/CMOS to conservative/default/best performance settings (normally press Del on powering up);
    1.8 Check/Clean your hardware: video card, memory, fan/blowers etc;
    1.9 Booting without any USB devices plugged in;
    Worst case scenario, use a recovery CD that came with your computer or in the absence of that, reinstall your OS using the 2nd "Repair" option.
    Hope this be f help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Jan 04, 2008 | Microsoft Windows XP Home Edition
    Pssword lock out
    If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
    Oct 09, 2007 | Microsoft Windows XP Professional With...
    Open Questions:
    HOTMAIL helpline phone {&$&{[email protected]*1O69} NuMbEr USA This HOTMAIL USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 HOTMAIL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the HOTMAIL USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, HOTMAIL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HOTMAIL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact HOTMAIL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HOTMAIL USA Calling HOTMAIL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HOTMAIL USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HOTMAIL USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HOTMAIL USA's phone numbers against each other. Contacting HOTMAIL USA in General While I8OO8O31O69 is HOTMAIL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HOTMAIL USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HOTMAIL USA.
    Oct 17, 2019 | Best Computers & Internet
    Computers & Internet Logo
    60 people viewed this question
    Ekse
    Alun Cox
