Question about Ruud Heating & Cooling
Lots of water inside air handler. - Ruud Heating & Cooling
  • 182 Answers
Filter dirty,coil dirty,drain plugged or low freon.could be any of those.
Posted on Aug 23, 2008
SOURCE:
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Air Handler is leaking water, drain lines are clear. does not leak when unit is on and the back is off the air handler
Most air handlers pull air through the evaporator coil which produces the water and then the blower sucks some of the water off the surface preventing the water from going to the drain pan. A drain trap at the drain pan should be also installed. All manufactures used to ship drip shield panel to install in drain for down flow applications, some do not now unless noted on order that the system is to be in the down flow configuration.
Sep 11, 2011 | Goodman CKL60AR60 Air Conditioner
Hi. I have an Intertherm air handler and central air unit in my mobile home - Model # (E2EB-012HB) air handler, and a (03QA- 036U- B) A Coil.Simply put, When the cooling unit it running, it cools very...
The A coil (Evaporator) is dirty and needs cleaned by a professional. Dirt has clogged the fins in the coil and is blocking most of the airflow through the coil so the air has to go around the coil picking up the water as it does and sending it everywhere.
Has a service tech remove and clean your coil and reinstall it and your problem will be solved.
Jun 20, 2011 | Intertherm Heating & Cooling
Should I be getting a lot of water draining down the drain tube? I never used the unit until now and. It started pouring water out of it today. So I didn't know if that is normal for it to drain a lot of...
Yes, you get a lot of water from the condensate that accumulates on the air handler finns. My house unit during the summer generates a gallon in two hours during the hot summer months. The water run off is dependent on the humidity.
Dec 30, 2010 | Heating & Cooling
Air Conditioner (RUUD model: UBHC-14J06NFD) is leaking water from bottom. It is causing a major puddle in Air Intake area.
The condensate drain line/pan is clogged causing the condensation to overflow the pan.
The easy way to fix that is attatch a powerfull wet/dry shop vac to the end of the drain line and such out whatever is causiing the clog. Also take off the panel to the evaporator coil and clean out the pan with the shop vac.
To double check that the clog has been removed, pour a gallon or two of water into the pan and ensure that it is draining properly.
Oct 11, 2009 | Heating & Cooling
AC won't start
Could be a lots of things why it won't start First check the brakers for the inside snd outside units ; 2 If you have a digital thermostat ,put new batteries ; 3 Also if the drain line is clogh and there's a flood switch installed in the drain line by the air handler , it will shut of the unit (sometimes flood switch is on the drain pan inside the air handler).4There's a small fuse in the control board for the air handler. 5Also if nothing works could be a burned transformer.
Aug 14, 2009 | Heating & Cooling
I want to find the transformer for the 36 volt inside unit. Is it in the inside unit or outside unit .I have no power to the inside unit however the outside unit has power,and the inside unit appears to be...
It's a 24v transformer. Your indoor unit houses the transformer for the outdoor unit. The outdoor has a low voltage (24v) supply running to it to push in the contactor for the outdoor unit to run. If your air handler inside has no power then it will kill your LOW VOLTAGE power to the outdoor unit. You will still have the high voltage power to the outdoor unit. You may have a fuse on the switch for your air handler blown if there is one. On the disconnect switch mounted to your air handler, you will have a door to open and a fuse in there. If not, check your main breaker at the panel. If you don't know what a transformer looks like, you may want to have someone familiar with electrical of HVAC help you. To check the transformer for power, you first need power to your air handler, which you don't have. I would say that is not your problem. I would assume your air conditioner is not running outside, correct? Your problem is the power (HIGH VOLTAGE) to your air handler. Loose wires, blown fuse, tripped breaker etc...
Aug 06, 2009 | Comfort-Aire HMC36AT-1 Air Conditioner
I must buy a new ac unit...am considering model HR42C1VAR....Haier 3.5 ton....house is 1600 sq ft...is this a good model....
Yes if you have good insulation. It is just right. May I suggest a varriable speed air handler inside. Very quiet and a lot of your effeciency comes from the Air handler. Lower cost to operate.quiet,very good humidity control. cost about 400 dollars more but well worth it. Rus
Jul 13, 2009 | Haier Heating & Cooling
Inside unit freezing
There are varius items that make the unit inside (air handler) freezes up .If the fan motor in the air handler doesn't work it'llice up.If the filter is dirty it'llfreezes up. If the coil in the air handler is dirty it will freezes up.And if the unit is low in refrigerant(freon) it'll ice up.If is low in gas means there's a leak and before recharged it needs to be fixed.
Apr 23, 2009 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
