Question about JVC Everio GZ-HD7 Camcorder
Downloading problems - distortion???
Hi! I was wondering if anyone would be able to point me in the right direction. When I play my recorded films back from my HD7 directly to tv via HDMI cable, everything is INCREDIBLE (crystal clear - just perfect). I am stuck, however, as to how i should now download without the images 'distorting'. I recently bought a JVC Share Station - which I returned as when i downloaded it onto the SS and played it back (again via HDMI) to my tv, the images were almost 'frame by frame' - whenever there was movement, it appeared as though the ??compression?? was wrong - it honestly looks like a staggered frame by frame instead of a smooth image. I have now bought an external hard drive but am STUCK as i do not have a PC with a HDMI output.....so hence the playback quality from my PC to tv is ordinary :o(. I understand that there are HD PC's out there....but i also believe there are ????Media Units???? which i may buy (and hopefully they do not have the same problems as the share station did). ANY A NY ANY advice would be so greatly appreciated!! :o) tina
I have my pc hooked up to my hdtv via vga cable and the video playback is as good as it is if i were to playback from camera through hdmi ,my screen resolution is 1360x768 which is slightly higher than standard hd but lower than full hd but honestly I doubt you could tell the difference.....ps if you have a graphics card that supports 1920x1080p and obviously the tv also, you dont need hdmi out on pc......vga cable does the same job! im running an nvidia 8800gtx
Posted on May 02, 2009
Crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Jun 19, 2008 | Crosley 0187SST Turntable
Hi On my Pansonic DMR-EZ49V, I get distortion along the bottom of the screen when playing back vhs tapes that have been recorded on an older machine, I have adjusted the tracking but it has made no...
This is a real bad problem to solve. Unless your new video has been set up badly, there's little you can do. You see it's like this either your old machine was set up badly or your new one was! To get your new one to play back the old ones would require the aligniment to be reset to the old machine settings. However when you put a new machine previous recording in - that would now badly track. A new recording (made after the adjustment) played back would be ok though.
The only way you can tell if the new machine is set up right is by putting in a commercial film video tape. If that tracks badly it has been set up wrong.
I can say this however Panasonic VCR's have a reputation of being set up well and good at tracking videos. So if it can't track the old video tape it might be well out of alignment, especially if it is not a Pansonic model.
If the old machine is still working, it would be best to play it back and re-record with the new machine.
Otherwise you would have to carry out an alignment - play back the tape and re-align back to the correct setting.
Sep 03, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
My camera will play back images but distorts new images
Hi!
It's faulty CCD (imager). Ask Sony if they change them for free there.
Tom
Jul 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Distortion when recording flute on cubase
K, 1st of all... Try listening to the files directly from the h4, before download to the nbook. No dist? Problem solved.
Otherwise, note the mics are really sensitive, even in low gain, any "wind" instrument, like your flute, my clarinet, or even the voice can generate distortion.
solutions:
1. You have a "monitor" mode in the h4, just check for it, easy to find. Then you can adjust details on the h4, as you play and listen the output.
2.check the distance you are playing from the mic, be generous with that, anyhow you can move higher the gain. :)
3. Don't play directly to the mic, as the air from your instrument may generate a noise that is not a note, but simply air coming through the mic.
Monitor through computer... I'm stucked trying to make it work with any recording program in Vista, don't know how to make the system rcognize the device.So, I can't help you, and by the way, do you know how to record in Windows??
Luck bro
Jun 17, 2008 | Zoom H4 Handy Recorder
Recording problem with LG DR275
Make sure your machine is well ventilated, mine had an overheating problem.
Apr 26, 2008 | LG DR275 Recorder
Pictures distorted play/record mode
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Mar 30, 2008 | Philips HDRW720 DVD Recorder
Panasonic DMRES15 DVD audio problem
Hi, i have a panasonic dvd recorder DMR-ES15, just wondering can that be unlocked to play region 1 dvd's?
Mar 03, 2008 | Panasonic DMRES15 DVD Recorder
Can this play all regions?
Press Setup
Scroll to Lock
Press 0 (7 times)
A message will appear saying it is region free
Nov 06, 2007 | LG RH177 DVD Recorder/HDD Recorder
JVC Everio GZ-HD7 Camcorder Logo
107 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
