Question about Microsoft Office 2003 Professional Edition
Office 2003 professional edition
I want to validate my offi 2003 prof edition, now im in the updates of offices 2003 (SP3) & I cant do this. windows required me to validate but my software i used now is invalid. plese help. thanks
    Sergeant:
  • 336 Answers
Call Microsoft and they will be able to help you with your problem. or call the manufacturer f the computer
RCF
Posted on Aug 31, 2008
Hi!! How are u? My english not good that much but i will try to explain my problem: when iam open my computerwhich work by windows xp sp3 i got massage the ip operator (3.0208.911.01) is not...
OK, sounds like the problem is that the computer cannot get a valid IP address. In fact it sounds like you might have a IP address conflict on your network. Each IP address on a network segment must be unique.
Check if you are using DHCP.
  • Go to
  • Control Panel
  • Network connections
  • Locate the network connection you are using e.g. 'Local area connection' or perhaps 'Wireless connection'
  • Right click on the relevant network connection
  • Select 'Properties'
  • Select Internet Protocol (TCP/IP)
  • Select Properties
Is your machine set to "Obtain an IP address automatically" (DHCP) or "Use the following IP address".
If its "Use the following IP address" then make sure no other machines are also using this IP address. You can try setting to 'automatic' but if you do, make sure that you note all details first, so you can revert back to the settings you currently have if you need to.
if its "Obtain an IP address automatically" then make sure no other machines have been manually set.
With regards to the microsoft update, then your best bet is to only select a small number of updates at a time, until you determine which update(s) is causing the failure. Once you know which update is the problem then you can troubleshoot the specific update.
Hope this helps
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Microsoft Computers & Internet
Tip
How to activate office 2007
Office Genuine Advantage (OGA) is another anti-piracy initiative by Microsoft on its popular business productivity product – Microsoft Office XP, Office 2003 and Office 2007. Similar to Windows Genuine Advantage (WGA), OGA requires users of the Microsoft Office software to validate their installed copy of Microsoft Office in order to download files from Microsoft Download Center, access updates or hotfixes from Office Update, and receive special offers for genuine users.
OGA is not to be confused with Office Product Activation that is mandatory required to during the installation process in order to use the Office software whereby users enter a serial product key that is validated online over the Internet or by phone by Microsoft to confirm that the product key has not been used on more personal computers than are permitted by the Microsoft Software License Terms. To crack Office XP/2003/2007 activation, you need a key generator that provides volume license key (Guide: How to change Office 2007 product key).
If you’re using a keygen-generated product key or publicly available leaked Office 2007/2003/XP serial number, especially the volume license key (VLK) that requires no activation when used, most of the keys no longer able to pass the OGA genuine validation test anymore with the following error message (Office 2007 as instance):
office-fail-validation.jpg This computer has failed validation.
Microsoft Office Enterprise 2007: Validation Failed
The product key used to install Office is not valid. It has been identified by Microsoft as a false key used with counterfeit copies of Office.
[0x80180108]
It’s likely that users who failed validation check may continue to use Microsoft Office as per normal and use Microsoft Updates to update critical patches. However, if you want to download add-ins, updates, templates, samples and tutorials, Smart Tags, Language Interface Packs and Software Development Kits (SDK) that require Genuine Office validation, you won’t be able to do so.
To bypass or crack the Microsoft Office 2007 and Microsoft Office 2003 OGA genuine validation, follow these steps:
  1. Install and activate Microsoft Office 2007 or other version of Office. If you intend to use the key-gen, you must install Enterprise edition.
  2. Download the patched ogacheckcontrol.dll.
  3. If you never validate your copy of Office, go to Genuine Microsoft Software web page, and run the Office Validation Assistant by using Internet Explorer (not Firefox as it will use different version of ActiveX component). This is to install the components required for Office validation. If you fail the validation – Office not genuine – simply ignore the message.
  4. Copy the cracked ogacheckcontrol.dll to the following location: Windows XP and Windows Vista (32-bit): \Windows\System32\
    Windows XP and Windows Vista (64-bit): \Windows\SysWOW64\
  5. Attempt to download Office files that require validation again. All downloads should work now.
The OGA Check Control crack works on Office 2007 Enterprise Edition, Office 2007 Blue Edition, Office 2007 Professional Edition, Office 2007 Pro Plus, Office 2007 Standard Edition and all Office 2003 Editions.
If you’re using invalid or blacklisted product key, you may have to change the Office product key (Guide: How to change Office 2007 product key). This is especially so if you’re using Microsoft Office 2007 Blue Edition.
Disclaimer: This patcher is for genuine Office user who having problem to pass genuine validation only. To use Office 2007, you must purchase a licenseir?t=techgadgetrev-20&l=ur2&o=1. Alternatively, you can use for free OpenOffice.org, an equally good productivity suite.
on Aug 02, 2010 | Computers & Internet
I want to update microsoft office 2003 to microsoft office xp 2007 professional edition full & final version
You can download the full version of microsoft office professional full version with keys via torrents.just add torrent downloads to the software name and search in google.
May 10, 2011 | Microsoft Office Professional 2007 Full...
Dont know how to install microsoftword in my pc
You can install office 2007 Professional Trial edition which is valid for a period of 60 days. Here is the download link
http://us20.trymicrosoftoffice.com/product.aspx?sku=3203819&culture=en-US&re_ms=variant-b
In case MS Office doesn't work you can try the Open Source based Office called Open Office Here is the download link
http://download.openoffice.org/contribute.html?download=mirrorbrain&files/stable/3.2.0/OOo_3.2.0_Win32Intel_install_wJRE_en-US.exe
Apr 07, 2010 | Microsoft Windows XP Home Edition for PC
Winword.exe 0010600b , at launch of word 2003, application freeze, message sorry encountered a problem need to close. tried renaming the normal.dot and data at regedit, problem still same. using win xp...
uninstall the software goto to regedit by typing it in run command and remove the microsoft registries for local machine and current user.
pls vote me if you find this helful.
Mar 26, 2010 | Microsoft Office Professional Edition 2003...
Office 2003 Programs Freeze
Is your office 2003 licensed?? If not you got nailed by microsoft and deactivated no doubt. If it is licensed, try reloading it. If that doesnt work repost the question and i will look further for you. You must delete the office 2003 completely and reinstall and if it is licensed, you can have microsoft update it. This is important.
Dec 17, 2009 | Microsoft Office Standard for PC
I have Windows XP 2003 Professional Edition, includes Word,Publisher, Excel,PowerPoint, but when I want to use any of this programs WINDOWS INSTALLER POPS UP and then Windows wants to configure MO Edition...
Assuming that you have the original CD-ROMs, with license-key, for Microsoft Office 2003 Professional Edition, available at your finger-tips:
Click: Start
Click: Control Panel
Click: Add/Remove Programs
Remove Microsoft Office 2003 Professional Edition.
Restart your computer.
Use the CD-ROMs, and re-install Microsoft Office 2003 Professional Edition.
Sep 10, 2009 | Microsoft Windows XP Professional for PC
MS office pro 2003
dear sir
please use the following key
MS Office 2003 standard edition
KDCTC-WC2XJ-TWJWH-MKM6M-GM29D
MS office 2003 prof.
GWH28-DGCMP-P6RC4-6J4MT-3HFDY
regards
murali
Apr 21, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Office 2003 Professional - Picture manager
Fixed the problem - Even though the pc checks for updates automatically I should have checked to see if there were any available updates at the microsoft website. There were 3 available and once downloaded and installed the picture manager part of office suite professional 2003 is now working just fine!
Sep 19, 2008 | Microsoft Office 2003 Basic Edition...
Microsoft Office 2003 Professional Edition Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
